i phone case that works with charging cradle
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Feb 28, 2024.
  1. Feb 28, 2024 at 2:35 PM
    SDHNTR
    SDHNTR [OP] New Member
    I've got an Iphone 14 with an Zagg case. It won't charge through the case when placed in the charging cradle. Works fine without the case. Anybody successfully using a case on a iph 14 that works with the cradle? Which case? thanks
  2. Feb 28, 2024 at 2:40 PM
    NOEVSh*t
    NOEVSh*t 53 Toyota Buys - 2016 382,000 M - 2011 528,000 M
    The Great State of Texas
    2024 Platinum 4X4 Non-Hybrid Night Shade Crew Max
    Start/Stop Disabled, Ceramic Tint, 305/55/20 BFG KO2's on No Lift or Level, EFF Replace OEM Charger, Wireless Charge Iphone Mount, Exceed Bed Cover, etc.
    apple's mag safe silicone case
  3. Feb 28, 2024 at 3:01 PM
    Breathing Borla
    AZ
    this ^
    I have this exact one and it works fine. 14 pro max
  4. Feb 29, 2024 at 9:17 AM
    SDHNTR
    Ok thanks. Bought an apple magsafe.
    Sixty9Four20 likes this.
  5. Feb 29, 2024 at 10:09 AM
    Breathing Borla
    AZ
    if it connects intermittently at all, try moving to the left (away from the raised portion of the charger) 1/4-1/2". I do have to move it around a little once in a while, but that makes sense with the shitty roads around here and it moving a bit from time to time.
  6. Feb 29, 2024 at 11:24 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
  7. Aug 28, 2024 at 5:15 AM
    Jrome27
    Jrome27 New Member
    '17 CM Limited
    3" Lift, 250psi compressor, 4g tank, air horn, air impact wrenchs, 2 Kicker CVR 10s, 800w MB Quart 4 Channel, Kicker 45 Old School
    I switched to an OtterBox, which has been working perfectly with my charging cradle. It seems like some cases just don't allow for the right kind of connection because of their thickness or material.
    Besides, I have some cases from here. They have a variety of cases, and you might find one that's compatible with your charging setup.
    Tundrastruck91 likes this.
  8. Aug 28, 2024 at 6:12 AM
    Midnight Rider
    Midnight Rider None of the above.
    Dave
    Wright City MO
    2023 Platinum Crewmax 4x4
    Cup grips & a 2 decals.
    +1 on the Spigen, iPhone 15 plus.
  9. Aug 29, 2024 at 5:27 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Does the MagSafe silicone really work?
    Mine shows “connected and charging“ if I believe the lights/icons but I always get the message of an obstruction and then it just seems to maintain the current charge level.
    when I take the case off it actually charges beyond the current level
