I only drive 300 miles per month but I want the 46 gallon TransferFlow. Bad idea?
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundrathr0w, Jun 13, 2018.
  1. Jun 13, 2018 at 2:08 PM
    tundrathr0w
    tundrathr0w [OP] New Member
    2018 Silver Sky Metallic Tundra CrewMax 4x4 5.7L
    I only drive 300 miles per month but I want the 46 gallon TransferFlow because I like the idea of rarely having to go to the gas station, having a lot of gas on hand for emergencies, etc.
    Is this a bad idea? Do I risk the gas getting stale and damaging my engine??
    Coachbuilder1 likes this.
  2. Jun 13, 2018 at 2:10 PM
    15whtrd
    15whtrd Mr. Blonde
    If you’re really worried you could just put some quality fuel stabilizer in with it. If you’ve got the money to spend and your state allows it. I say go for it.
  3. Jun 13, 2018 at 2:10 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    No problem. The gas will not go stale
  4. Jun 13, 2018 at 3:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Or buy non-ethanol gasoline.
    Scpringle and Pudge like this.
  5. Jun 13, 2018 at 3:16 PM
    Gasoline is good for approximately 1 year without additives.
    Good. To. Go.
  6. Jun 13, 2018 at 3:18 PM
    tundrathr0w
    Does non-ethanol gas not go bad?
  7. Jun 13, 2018 at 3:20 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I let my Nissan sit for six or so months. Started it up and drove it around just fine. If you have the money for that giant tank, knock yourself out. I wish they made a bigger tank for the first gens.
  8. Jun 13, 2018 at 3:29 PM
    Always ..........................[​IMG]....:thumbsup:
    jewsNbrews and 15whtrd like this.
  9. Jun 13, 2018 at 3:30 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    I don't blame you at all, Its like knowing of 2 bad guys on your street but keep 500 rounds close by?? Your fuel will be fine for a few months :thumbsup:
    jewsNbrews, 15whtrd and Black Wolf like this.
  10. Jun 13, 2018 at 4:19 PM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    heart wants whats the heart wants :)
  11. Jun 13, 2018 at 8:04 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I like that it doesn't tend to absorb moisture from the atmosphere, so I always put it in my vehicles that sit for extended periods. An example would be my 70 El Camino that has a vented gas tank. Honestly, I don't think that's probably an issue with the modern EVAP systems. If you're driving 300 miles a month, and even with a 46 gal tank, you're likely burning it all before it could "go bad", even if you're topping up "along the way".
  12. Jun 13, 2018 at 9:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m putting about the same miles on as you. My 2015 just turned over 10,000 miles. The 46 gallon transfer flow tank is one of my best mods. Worth every penny.
  13. Jun 13, 2018 at 10:02 PM
    tundrathr0w
    What's your refueling strategy like? Refuel at half? Refuel at empty? I bet with the 46 gallon + infrequent driving, you pretty much never go to the gas station??
  14. Jun 13, 2018 at 10:13 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I usually go all the way to empty. Once i went 80m after the light came on. l was clenched so tight i left a permanent ridge in the middle of my seat. You’re better off keeping it full though, so there’s less room for condensation. It’s months between filling up.
    jewsNbrews likes this.
  15. Jun 13, 2018 at 10:16 PM
    tundrathr0w
    And you've had no problems with fuel pump or anything else, always burning older fuel?
  16. Jun 13, 2018 at 10:18 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    No problems with anything. I did put some Stabil in for a while 2016-2017,but decided it wasn’t really necessary
  17. Jun 13, 2018 at 10:20 PM
    blizz86
    blizz86 New Member
    Lol if your pockets are burning full of cash. But if I were you I wouldn’t.
    joonbug likes this.
  18. Jun 14, 2018 at 7:41 AM
    tundrathr0w
    Why not?
  19. Jun 14, 2018 at 7:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I agree. If you’re out in the middle of no where or wheel in the desert... maybe. But not just so you can fill up every couple of months. I think that money could be spent wiser.
  20. Jun 14, 2018 at 7:55 AM
    phiredrop
    phiredrop New Member
    2015 MGM Tundra Platinum
    Did you upgrade the tank yourself? I reached out to my local Toyota Dealer about upgrading from the 26 gal tank to a larger one and they were like "We've never heard of this, it's never been done, it would cost you $4500 in parts alone, blah blah blah".. needless to say, I wasn't expecting that kind of an answer!
  21. Jun 14, 2018 at 7:58 AM
    blizz86
    blizz86 New Member
    Are you taking long trips? like @joonbug said - why waste money on this when theres so many other things you could get for your truck instead
    joonbug likes this.
  22. Jun 14, 2018 at 8:32 AM
    tundrathr0w
    Thanks a lot for your input! Where would you personally put the $1500+ instead?
  23. Jun 14, 2018 at 8:39 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  24. Jun 14, 2018 at 8:59 AM
    blizz86
    blizz86 New Member
    suspension, tires, better headlights (unless you have a 2018, those stock leds are nice), tints if you're somewhere warm, armor
    joonbug likes this.
  25. Jun 14, 2018 at 9:06 AM
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    @gosolo is your truck just parked in the garage a majority of the time? I'm interested in what people are doing with trucks that are practically stored until needed on a trip (i.e. keeping truck sealed, covered, etc.) I now am driving a company truck around a majority of the time and have the tundra parked except for camping trips.
  26. Jun 14, 2018 at 9:12 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    First off, if you got stuck with the stoopid 26g tank it’s not a waste. In fact it’s really a waste to continue to live with that. Second, what rule says buying one mod keeps me from buying others. I have every mod on my truck that I want.
    15whtrd likes this.
  27. Jun 14, 2018 at 9:16 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yes it stays garaged 100%. I have it on a battery tender so it won’t go dead. It’s still got a little “new truck” smell (VOC’s)
    15whtrd likes this.
