I need recommendations on a couple of things.
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Mar 31, 2025.
  1. Mar 31, 2025 at 8:10 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    1. Windshield sun shade for my 2015 Tundra.
    I’ve gotten two from Amazon, and both fit too small. I’d like one that fits just right and does a good job on blocking the heat. Easy to store away would also be great.
    2. Cargo net
    I need one that can stretch pretty good, so I can haul a lot of luggage with, without feeling like it’s going rip apart. Got a big event at church and I’m one of the few with a pickup so.. :)
    thanks in advance
  2. Mar 31, 2025 at 8:19 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
  3. Mar 31, 2025 at 8:23 AM
    seydou
    seydou Distinguished Member
    Covercraft make the best shades IMO. Not the cheapest though.
    You wanting to put a bunch of luggage in the bed and secure it with a net? Get the right size, otherwise they all seem to be about the same quality. They will wear out in a few years. Good thing they are cheap.
  4. Mar 31, 2025 at 8:24 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
  5. Mar 31, 2025 at 8:39 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I had a covercraft and it was expensive, high quality and fully covered the windshield and I hated it. It was huge and hard to store out of the way, it was also annoying and difficult to deploy. I ended up selling it and getting a cheap one on Amazon that deploys in seconds and I can fold it and stuff between pr under a seat in seconds as well.
  6. Mar 31, 2025 at 8:47 AM
    Tundra family
    Tundra family New Member
  7. Mar 31, 2025 at 8:53 AM
    SD Surfer
    Bruce
    So Cal
    I got one of the silver reflective accordion style from my local O'Reilly's and it's a pretty good fit, maybe a 1" gap at most in the top corner. Just measure your windshield and check against the dimensions of the shade. (I think it's the "Jumbo" size)
    https://www.amazon.com/BDK-Car-Wind...lective+windshield+shade,aps,129&sr=8-16&th=1
    Not as easy to stow as the little round ones that coil up but way better at blocking heat. The one I've got almost feels like it has bubble wrap, or some sort of air gap between the two silver skins.
    I think it was only $15-$20
    Can't help with the cargo net, I've got a tonneau.
  8. Mar 31, 2025 at 8:56 AM
    seydou
    Have never found one to be too big or hard to deploy or put away. The bigggest negative about the "easy" thin ones is that they do not insulate nearly as well. YMMV
  9. Mar 31, 2025 at 9:58 AM
    MadMaxCanon
    This is true as far as insulation but being that I have ceramic uv blocker on the windshield, it's not as much an issue.
