I need help with this
Discussion in '2nd Gen Tundras (2007-2013)' started by Sancho 8507, May 15, 2025 at 1:26 PM.
  1. May 15, 2025 at 1:26 PM
    Sancho 8507
    Sancho 8507 [OP] New Member
    Yesterday
    1. I need help i changed both my check valve and pumps on my 2012 4.6 toyota tundra and the codes never went away sick with p2438 how do I test the check valve they're aftermarket. I know the pumps work tested them already
    2. Codes that popped up
    3. 2441,2443,2447,2438
  2. May 15, 2025 at 2:04 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Did you ever clear them?? If you don't have an obd 2, you can always pull the negative terminal 30 seconds and reconnect it and see of they come back at all
  3. May 15, 2025 at 2:21 PM
    Sancho 8507
    Yesterday
    Yes a cleared them and them pop back up
  4. May 15, 2025 at 2:27 PM
    blackdemon_tt
    They may be bad to begin with. They may need further troubleshooting though. Maybe a damaged wire or ground.
  5. May 15, 2025 at 2:32 PM
    Sancho 8507
    Yesterday
    I put the old ones on and same code but I could clear them and they wouldn't come back on unless I restarted the truck
  6. May 15, 2025 at 4:15 PM
    blackdemon_tt
    Sounds like they're bad out of the box, or the wrong units.
  7. May 15, 2025 at 5:23 PM
    Sancho 8507
    Yesterday
    I think so I put the old ones back on got rid of p2438 now just have the 2441,2443,2447
