I need help with this
Discussion in '3rd Gen Tundras (2022+)' started by ykyss, Jul 5, 2023.
  1. Jul 5, 2023 at 1:17 PM
    ykyss
    ykyss [OP] New Member
    Just bought aeroskin lightsheild hood guard. I need a help from all professional hobbiest. There is cable needs to hook up to ground(black) and marker light(red) circuit. Mine is hydrid 23 tundra...its little confused. Any one have same issue? Or had experience for install? Please help. Thank you.
  2. Jul 5, 2023 at 7:30 PM
    Limitrd
    Limitrd New Member
    Oregon
    22 Lunar Rock Limited Hybrid TRD Off Road CM 6.5
    I can not help with the answer to your question, sorry about that part. I am interested in how it turns out, and your opinion of it. Please post pictures when you install it. Maybe giving a little more info about your truck would help? Trim, packages. I think it might make a difference if you have the snazzy upgraded headlights.
  3. Jul 5, 2023 at 7:37 PM
    Welcome from NY.
    Why not put the black wire on a body bolt under the hood for the ground and tap the red wire on either a headlight + or marker light +? This way it will come on with just the marker lights or when the headlights are on. No switch is needed. I would definitely put a in-line fuse on the red + wire though.
    Hopefully this makes sense to you
  4. Jul 6, 2023 at 4:07 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Agreed... Ground the black wire to either the battery or one of the many chassis/body grounds under the hood. For the positive wire, get a fuse tap similar to the one I linked. Make sure you double check the type of the fuse you are using as they make taps for every type of fuse out there. Just select a fuse that is only on with your headlights or parking lights.
    This method keeps you from tapping into any wiring and potentially causing expensive damages.
    FuseTech 12V Micro2 APT ATR 17 Piece Automotive Car Fuse Assortment and Holders Pack (2 Add-a-Circuit Fuse Tap Adapters, 14 Blade Fuses + Fuse Puller) 5A 7.5A 10A 15A 20A 25A 30A
