I need help installing door courtesy lights
Discussion in 'Lighting' started by Tundros, May 31, 2015.
  1. May 31, 2015 at 2:06 PM
    Tundros
    Tundros [OP] New Member
    Johnnie
    Hawai'i
    2011 Gray Tundra Dbl Cab 5.7L 4x4
    Aftermarket front and rear lights, added fog lights, bed liner, bull bar, bed cover, chrome door handles, chrome mirrors, side steps, AFE stage 2 Short RAM intake, Pioneer stereo, Alpine 6x9 front door speakers, 6in Pioneer round speakers rear door, 1 12in Pioneer sub with 1200 watt Sony Xplode amp. Toyota door logo courtesy lights and 20in black and machine rims on 275/60 Cooper HT plus M&S tires also painted red calipers. Also painted red Toyota emblem.
    I have a 2011 Tundra and we all know they don't come with real door lights. Well I purchased aftermarket door lights and I'm having issues finding the correct wires to splice into within the floor panels. Can anyone assist me?
  2. May 31, 2015 at 2:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I added lights under the footwells and tied into the one light under the drivers side footwell that comes on with the door open. Not sure about what wiring is in each door.
  3. May 31, 2015 at 2:42 PM
    Mike Tread lightly.
    south carolina
    Have to use a diode at every door pin to make them work them per door.
  4. May 31, 2015 at 4:06 PM
    Tundros
    Johnnie
    Hawai'i
    So that little light bulb under the footwell gave enough power to power both sides?
  5. May 31, 2015 at 4:17 PM
    Mike Tread lightly.
    south carolina
    Leds like that are in milliamps not amps.
  6. May 31, 2015 at 8:01 PM
    csuviper
    Broomfield, CO
    Yep all 4 footwells. Front and rear.
  7. Jun 18, 2015 at 5:13 PM
    Tundros
    Johnnie
    Hawai'i
    image.jpg Ok so I recently posted asking how to door courtesy door lights. Well I have completed the task. If you are interested I can tell you how I did it.
    NewImprovedRon, LTD_Toy and T-Rex266 like this.
  8. Jun 18, 2015 at 6:23 PM
    Branj
    Branj New Member
    Nate
    2015 TRD PRO
    I think you should do a MOD write-up on this and post it.
    panicman, NewImprovedRon and T-Rex266 like this.
  9. Jun 18, 2015 at 6:26 PM
    Tundros
    Johnnie
    Hawai'i
    sounds good. I will post it sometime tomorrow.
    NewImprovedRon likes this.
  10. Jun 18, 2015 at 7:33 PM
    Agreed! Definitely enter it into our unique mod contest too!
  11. Apr 17, 2016 at 9:45 PM
    LTD_Toy
    LTD_Toy New Member
    California
    2011 Tundra Limited
    Hey Johnnie,
    I have been waiting to see your post. I am about to do the same thing myself. I have the lights but they did not come with the harness to plug into the light. It would be great to see how you did it.
  12. Jul 7, 2016 at 6:32 PM
    DANSEVO
    DANSEVO New Member
    Tundros Did you locate wires in the door to tap into? I'm looking at doing this same mod! Or does anyone else know?
  13. Jul 7, 2016 at 8:12 PM
    Island woody
    Island woody New Member
    Scott
    2016 crew max 4x4
    Lift kit, Borla exhaust, 35 inch tires
    I did the led in the footwell too, works great, just tapped into factory light wires in footwell
  14. Jul 7, 2016 at 8:47 PM
    DANSEVO
    DANSEVO New Member
    Ok I understand that you can do that but to tap into that and run power into all four doors is a lot of work if there are wires that are already hot for the courtesy lighting. I'm curious if there are wires in each door that you can tap into to power the courtesy lights if installed. Has anyone tested the wiring harness for courtesy power before?
  15. Feb 6, 2019 at 7:33 PM
    Punisher4x4sr5
    Punisher4x4sr5 New Member
    I have 2 70 inch led strips. 1 on each side for running lights. I want to hook up the courtesy lights. Where do I need to tap in to get enough power?
  16. Feb 6, 2019 at 7:34 PM
    Punisher4x4sr5
    It's a 2016 Toyota tundra double cab 4x4
  17. Mar 23, 2019 at 2:12 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Anyone know about the harness that would be in the door if the truck came with puddle lights? Buddy of mine has a 12 rw. He bought some lights that project tundra on the ground. They appear that they should be plug and play with a truck that came with those lights, his did not. I'd like to be able to buy the pigtail from say Roman but I dont know if I even can. Anyone got any ideas
