I need a body mount chop and some trimming near knoxville
Discussion in 'Wheels & Tires' started by Cabs, Dec 17, 2017.
  1. Dec 17, 2017 at 9:55 AM
    Cabs
    Cabs [OP] New Member
    2017 1794 3/1 lift level on 33's rubbing bad need this fixed asap. Let me know a great place to have this done. Thanks
  2. Dec 17, 2017 at 10:09 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    What size rim? 33 shouldnt be rubbing
  3. Dec 17, 2017 at 10:18 AM
    Rubbing on the front fender liners or cab mount? I'm assuming the cab mount but like Tony ^^^said...tire size...rim offset?? 33s shouldn't rub.
  4. Dec 17, 2017 at 11:53 AM
    Cabs
    20 inch rim
    Pudge likes this.
  5. Dec 17, 2017 at 1:08 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Aftermarket wheels?
    What is the offset? I have 33s on OEM platinum rims, no lift and I have zero rub
  6. Dec 17, 2017 at 1:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :worthless:
    Help us help you.
  7. Dec 17, 2017 at 2:50 PM
    Cabs
    20" rims, 33" 305/55/20 faulken at's, monster 20x9 wheels not sure of offset where do i find that?
  8. Dec 17, 2017 at 2:53 PM
    Pudge
    CT
    Oh 305s are wide. Check spec on rims to get offset
  9. Dec 17, 2017 at 3:02 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you take the wheel off, it’s usually stamped on the inside somewhere with an ET next to the number. Your wheels are outside the fenders with 305 tires... looks like you might need the CMC.
  10. Dec 17, 2017 at 3:04 PM
    Cabs
    i will dig through paperwork tomorrow thanks for all the help guys.
  11. Dec 17, 2017 at 3:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s pretty obvious you have a very low offset. Really doesn’t matter what it is. If you’re hitting the cab mount you need a CMC or you’d have to get new wheels.
  12. Dec 17, 2017 at 4:00 PM
    Cabs
    Not doing new wheels lol. Do you know anyone in the Knoxville, TN area that can do the work?
  13. Feb 7, 2018 at 8:56 AM
    Gibzki
    Gibzki New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    wheel spacer should fix this?
  14. Feb 7, 2018 at 9:18 AM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    a spacer would push it out further making his problem worse
  15. Feb 7, 2018 at 10:32 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    See if you can get ahold of Rock Your 4x4. Ive delt with them in the past, and have nothing but positive things to say about them.
  16. Feb 19, 2018 at 6:42 PM
    =57=
    =57= New Member
    Plano, TX
    2015 Black Tundra TSS Crewmax
    Interior/Exterior LEDs, Winjet smoke tail lights, BullyDog Tuner, painted 3rd brakelight, Retrofit projector headlights done by Eledobleu, TonnoPro Tri-Fold Tonneau Cover, BAM 8" exhaust, 35" Nitto Ridge Grapplers and 20" Fuel Assaults
    I need to get the body mount chop myself and called a 4wheelparts.com store in Orlando. Their website shows they have a location in Nashville or Memphis. I was given a $250 quote less than a week ago if that helps
