I MUST be blind “2011” Tundra transmission on the
Discussion in '2nd Gen Tundras (2007-2013)' started by Danjojo55, Oct 15, 2019.
  1. Oct 15, 2019 at 6:41 PM
    Danjojo55
    Danjojo55 [OP] New Member
    2011 Tundra
    I really must be blind and so far the videos i’ve looked at have not helped.
    I am looking for the fill plug on the transmission.
    Would someone have a few clear pictures of the fill port that would show the port relative to driver side or something.
    Don’t know why I can’t see this, your help is much appreciated.
    Daniel
  2. Oct 15, 2019 at 7:13 PM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    This is from a 2015 shop manual, but should be the same:
    Danjojo55[OP] and TokerJoker like this.
  3. Oct 15, 2019 at 7:39 PM
    Danjojo55
    2011 Tundra
    Great this should help because the videos i’ve Watched have directed me to the drivers side toward the front, this shows just the opposite.
    Thank you, I’m tied up tomorrow but will get on this soon after.
  4. Oct 15, 2019 at 7:48 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Search youtube "Tundra Transmission fluid drain and fill" 07 to 13 are all the same. They will show where the fill plug is.
    It is on the driver's side, at least my 07 was on the drivers side.
    Edit: mine is 5.7
  5. Oct 15, 2019 at 9:18 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    My 2011 didn't have a fill plug filled it through the trans cooler line . The fill plug wasn't not an actual plug. Haynes book showed the same thing and it wasn't there.
  6. Oct 15, 2019 at 9:32 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    2012 5.7 2WD. It’s on the drivers side.
  7. Oct 16, 2019 at 1:00 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    2008 : The plug is labeled WS and it's on the driver's side toward the engine
    Zebruaj likes this.
  8. Oct 16, 2019 at 6:57 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It depends on which engine/transmission you have. All the answers above are correct, but for different transmissions. Which do you have?...Engine size, and if its 2WD or 4WD, will work.
  9. Oct 16, 2019 at 9:11 AM
    Danjojo55
    2011 Tundra
    4.6 2WD
  10. Oct 16, 2019 at 12:44 PM
    JohnLakeman
    For 4.6L 2WD, @Opus5150 is correct. Fill plug is on the PASSENGER side, tail shaft housing. Look for the "WS".
  11. Oct 16, 2019 at 6:16 PM
    Danjojo55
    2011 Tundra
    Yes John, @Opus5150 is correct and I have found it late this evening.
    I have serviced with 4 qts so far, it's all I had on hand. While in town I will pick up 4 more.
    All is going well, thank you everyone!
    JohnLakeman likes this.
