I messed up my tow mirrors. What would be the replacement cost?
Discussion in '2nd Gen Tundras (2007-2013)' started by Thomas4x4, Apr 1, 2024.
  1. Apr 1, 2024 at 2:26 PM
    Thomas4x4
    Thomas4x4 [OP] New Member
    Thomas
    2008 Toyota Tundra SR5
    This is my second self-inflicted accident with my tow mirrors (they are certainly tough but can cause trouble). I side swiped my passenger side tow mirrors by a stop sign trying to avoid another truck that was coming over too close to where I was. The end result was marks on my tow mirrors and the glass coming off (but it’s not shattered). I put it back in place but it jiggles as I drive it.
    I ordered an OEM replacement passenger side tow mirror from Olathe Toyota Parts. I was watching videos on YouTube on installation and don’t believe it’s something I can tackle on my own. How much would it cost if I had someone install it for me and I provide the part? I haven’t had the chance to call yet.
    Julikins53 and Leo's first like this.
  2. Apr 1, 2024 at 2:32 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    post your location and you might have a fellow member nearby that can assist
  3. Apr 1, 2024 at 2:35 PM
    Thomas4x4
    Thomas
    Macon, Ga
  4. Apr 1, 2024 at 2:36 PM
    RobertD
    Robert
    DFW, Texas
    You should be able tackle this without too much issue if you are replacing a mirror with similar options. A second set of hands will help with door skin removal, but otherwise it should be pretty easy to un-bolt the old, disconnect. Connect the new, bolt it up, and then put the door skin back on.
    Thomas4x4[OP] and 1lowlife like this.
  5. Apr 1, 2024 at 2:37 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    There isn't much to swapping the mirror.
    It would help to have someone hold it while you swapped them.
    Pull the door panel, that's easy.
    Unplug it and remove 3 nuts, or remove 3 nuts and unplug it.
    Make sure you don't drop any of the nuts down in the door.
    It's a bitch to fish them out.
    DO the reverse to install, replace the door panel.
    The dealership will change a minimum of 1 hour for labor.
    I think that runs over $110 per hour.
  6. Apr 1, 2024 at 2:42 PM
    Thomas4x4
    Thomas
    What do you mean by replace the door panel? Is that something I should be ordering as well?
  7. Apr 1, 2024 at 2:43 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  8. Apr 1, 2024 at 2:45 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    No, I meant put it back on, reinstall it.
    You might not even need to pull the door panel, I can't remember exactly where those nuts are in reference to the door panel.
    EDIT.
    Yes you do need to pull the panel..
    The bottom nuts are behind the panel..
    This guy says you may just be able to pull the panel back to access those nuts..
    https://youtu.be/NJi-_AUdYeQ?si=dfmEuxmtc8r-RTX7
  9. Apr 1, 2024 at 3:39 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    You can do this but I understand not wanting to dick around with it especially if you have my luck
    Call around to local repair shops I'll bet you can have it installed for 100 bucks
    It really is a pretty easy job though I've done it twice on my 07 :anonymous:
  10. Apr 3, 2024 at 5:22 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Setting aside labor costs, if you have screwdrivers and socket wrenches it's quicker to replace them yourself than to deal with dropping the truck off at a mechanic.
  11. Apr 5, 2024 at 1:33 PM
    Thomas4x4
    Thomas
    Well, I feel a whole lot better. When the part came in this morning, I went straight to the dealer ($150 just for labor). Now, I just hope that I don’t make anymore mistakes.
    Leo's first, Julikins53 and PhotoNerd like this.
  12. Apr 9, 2024 at 10:26 PM
    Julikins53
    Julikins53 New Member
    Simi Valley, CA
    2013 Red CrewMax Limited
    Remote start
    I replaced my original non-tow mirrors on my 2013 Limited with Platinum tow mirrors. Also ordered from Olathe. My mechanic did it for me and said it was easy.
    Thomas4x4[OP] likes this.
  13. Apr 11, 2024 at 9:13 AM
    Thomas4x4
    Thomas
    Ok this just happened today. This piece by the inner door knob got loose. I can never expect perfection from some techs at the dealer. I’m trying to see if I can get it back in place.
  14. Apr 11, 2024 at 9:36 AM
    PhotoNerd
    Tony
    Waterford, CT
    It just snaps in place but maybe they broke the clip. I'd probably just use some double-sided tape if it doesn't clip in.
  15. Apr 14, 2024 at 5:15 AM
    Thomas4x4
    Thomas
    It still won’t snap back in. Would i have to buy another clip?
    Leo's first likes this.
  16. Apr 14, 2024 at 7:43 AM
    Leo's first
    Groton ma
    Why aren't you taking back to the dealer? You've already wasted the time it would take and spent the money to have the job done right
