I love speeding
Discussion in 'Suspension' started by Samoan Thor, Oct 14, 2017.
  1. Oct 14, 2017 at 5:06 PM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I love fast type off-roading there’s no speed limit in the desert and I want to upgrade my suspension. I think with more travel it can do great in any type of terrain. I got kings f&r for now, help me choose.......
    1. 3.0 front coilovers with 3.0 bypasses in the rear(kings of course)
    2. Pair a 3.0 bypass shock with my current 2.5 for dual shocks up front then possibly deavers spring under in the rear with bumpstops or just a bypass in the rear stock length
    3. Total chaos long travel kit, camburg LT kit or mazzulla
    Number 3 is the absolute last as it is expensive and if I want to keep my bed the cantilever option is even more moneys! More travel would be nice as well, how can I increase wheel travel without going full long travel? I know uni ball UCA’s add about an inch to travel, anything else? Thanks
    CJ21 likes this.
  2. Oct 14, 2017 at 5:15 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Other than going with a upper and lower control arm swap in the front, you're not gonna achieve the desired travel numbers you want with just a UCA swap. TC, Camburg and Mazzulla all make a great product. Having had the Camburg kit on my old truck for 10+ years it eventually developed "The Camburg Creak". I've seen a Mazzula shock tower crack, but that guy was hammering his truck really hard.
    As for the rear, a Deaver leaf pack and bypass will get you the travel without having to go with a cantilever setup. Anything more than 13-14" inches of travel I highly suggest installing a full rollcage. You start heading down a slippery slope after that.
    More travel = more speed = more trouble you can get yourself into.
    SoCal619, Sunnier, TheBeast and 2 others like this.
  3. Oct 14, 2017 at 5:21 PM
  4. Oct 14, 2017 at 5:35 PM
    Samoan Thor
    Good points mr baja, I've seen people running dual shocks up front with stock LCA so I might do that. I know my limits, I've ran my kings pretty hard and got a little airborne to where it sounded like i broke something but luckily the tundra still remains solid, i think ill stay with a good mid travel setup. Ive enjoyed going fast in the desert but i know the limits and I don't want a roll cage, at least not yet I might change my mind but mid travel is better i think cuz it won't increase the track width but is kind of a sacrifice. I know i want more travel but don't want the tundra to be wider, tundras are too big for LT so i might scratch that off the list, thanks.
    ColoradoTJ likes this.
