I just purchased a Trundra 2016 5.7L. My first question is. Can I tow a trailer that weights 8350lb?
Discussion in 'New Member Introductions' started by Macaroo, May 5, 2021.
  1. May 5, 2021 at 6:44 PM
    Macaroo
    Macaroo [OP] New Member
    John Mc Murray
    Toyota Trundra 2016. 5.7L
    I just purchased a Trundra 2016 5.7L. My first question is. Can I tow a trailer that weights 8350lb?. Down the road with no difficulties.
  2. May 5, 2021 at 6:47 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I guess it depends on configuration of Cab 2 vs 4wd and hitch. People may need more details.
    Booney likes this.
  3. May 5, 2021 at 6:54 PM
    Macaroo
    John Mc Murray
    My Tundra is equipped with 4WD, tow haul,
  4. May 5, 2021 at 6:58 PM
  5. May 5, 2021 at 7:21 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  6. May 5, 2021 at 7:46 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  7. May 5, 2021 at 8:19 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    :popcorn: patiently waiting for all the Towing Karens to show up......
    But you should be fine. Check your door sticker
    I_Am_Thee_Walrus and NWPirate like this.
  8. May 5, 2021 at 8:30 PM
    Cpl_Punishment likes this.
  9. May 5, 2021 at 8:43 PM
    NWPirate
    Zach
    WA
    Short answer, of course you can.
    But..
    I wouldn't if it's a travel trailer, my 6,200lb TT with 650-700lb tongue weight is enough for me.
    I probably would if it's a dump trailer. (Depending on tongue weight)
  10. May 5, 2021 at 8:45 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Why do people keep asking if it can tow their trailer right after buying the truck?
  11. May 5, 2021 at 8:45 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Biggest limiting factor on our truck is payload. Your factory door sticker will tell you what yours is. 4WD is a negative in this case because it weighs more and reduces payload.
    The trailer hitch weight is usually about 10% of the trailer weight itself. You will likely be pushing it once you add all the weight of all passengers and bed cargo.
  12. May 5, 2021 at 9:10 PM
    NWPirate
    Zach
    WA
    I thought the same thing, cart before the horse!
  13. May 6, 2021 at 3:47 AM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    It’s fine. Go slow, use a WDH if you have one. The shorter the trip, the better
  14. May 6, 2021 at 4:15 AM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    Pun intended?
    NWPirate[QUOTED] likes this.
  15. May 6, 2021 at 4:32 AM
    IndianaGeologist
    IndianaGeologist New Member
    What no one ever says though is that if you are over on your payload or weight limits you accept all liability. So don't get in a wreck because if the do the math you'll be getting no financial or legal help.
    Karen signing off
    mikey14 likes this.
  16. May 6, 2021 at 4:40 AM
    AZBoatHauler
    So.Arizona
    Where does it say that in your insurance policy?
  17. May 6, 2021 at 4:42 AM
    IndianaGeologist
    I'm not going to post my policy . Don't be lazy, Google it yourself or use common sense.
    But to break it down, your breaking laws, so do you think your insurance will cover you?
  18. May 6, 2021 at 4:45 AM
    AZBoatHauler
    So.Arizona
    Okay. I won’t use my 12 years experience as a civil litigator handling cases that include crashes involving overloaded vehicles.
    :rolleyes:
    Keep spreading bad info. :fistbump:
    I_Am_Thee_Walrus, WBW and Prostar 190 like this.
  19. May 6, 2021 at 4:47 AM
    Welcome from Ohio.
  20. May 6, 2021 at 4:48 AM
    AZBoatHauler
    So.Arizona
    Ever heard of people causing a wreck while driving under the influence of alcohol? Last I checked that was illegal yet the insurance carriers continue to pay the claims.
  21. May 6, 2021 at 4:49 AM
    From Lawyers. Take it or leave it. Check your ratings for your truck, weigh it, and make an informed decision.
    IndianaGeologist likes this.
  22. May 6, 2021 at 4:54 AM
    IndianaGeologist
    Ok fine, if this is your job, do you have any cases of pp
    It's not just will your insurance cover it, but if you're found negligent and damage other peoples property and/or injury, then you'll be spending lots of time in civil court working through this issue and can report back and let us know.
    mikey14 likes this.
  23. May 6, 2021 at 4:58 AM
    ANYWAY, The OP's trailer is within the max towing capacity, and assuming it's over payload doesn't help anything right now. Especially not in a thread that is meant to welcome a new comer. Let's be on our best behavior, Gents.
  24. May 6, 2021 at 4:59 AM
    AZBoatHauler
    So.Arizona
    Had mediation for a wreck caused by an overloaded Ford Ranger on Monday... the insurance carrier is paying for the defense of the lawsuit and the damages for the claim.
    Of course a person is at fault for their negligence assuming it causes damages - the question was do they void insurance coverage by towing over the manufacturer’s rating.
    Twowheelssoar likes this.
  25. May 6, 2021 at 5:02 AM
    AZBoatHauler
    So.Arizona
    OP,
    I suspect you’ll be close to or over payload capacity. Hit a scale to verify you aren’t over GVWR or your rear axle rating. (See door jamb on driver’s door for your ratings)
    Welcome! :)
  26. May 6, 2021 at 6:04 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! And as you can see, we have knowledgeable people on the site ready to help!
  27. May 6, 2021 at 6:20 AM
    Dupey
    Dupey I love chips and salsa!
    Northern Colorado
    2014 tundra platinum
    TRD PRO GRILL TRD PRO HEADLIGHTS W/I hacker ADAPTER WIRING WEATHER TECH FLOOR LINERS C4 FRONT BUMPER WITH 30 inch LIGHT BAR RCI ROCK SLIDERS RCI SKID PLATE RCI LOW PROFILE BED RACK ARB TOURING ROOF TOP TENT TOYTECH 2.0 FRONT COILOVERS TOYTECH REAR SHOCKS TOYTECH 1.75 SHACKLES
    Welcome! :popcorn:
  28. May 6, 2021 at 6:26 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Booney likes this.
  29. May 6, 2021 at 6:26 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    You will need a weight distribution hitch but yes, you should be fine. 8300lbs is more or less maxing out your truck.
  30. May 7, 2021 at 8:14 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
