I just got progressive lenses....any advice or tips?
Discussion in 'Off-Topic Discussion' started by Solid Snake, Jul 27, 2025 at 11:23 AM.
  1. Jul 27, 2025 at 11:23 AM
    Solid Snake
    Solid Snake [OP] The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I started wearing prescription glasses a few months ago. I opted for single vision lenses for distance seeing. Well, looking at things up close like my phone became a pain in the butt. So I upgraded to progressive lenses. While they do correct my vision for distance and up close, they're going to take some getting used to. Any tips or advice from you veterans of the glasses world?
  2. Jul 27, 2025 at 11:33 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    They will feel weird for a few days. You’ll get used to it to them. You need to start moving head up and down to focus as the lens focuses differently as you move up and down the lens.
    WILLINH likes this.
  3. Jul 27, 2025 at 11:34 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Own both
    can’t watch tv with bifocals
    Mdl likes this.
  4. Jul 27, 2025 at 12:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I could never get used to progressive lenses. I went back to single vision and just raise them to look at my phone or read.
    Tripleconpanna likes this.
  5. Jul 27, 2025 at 1:10 PM
    Retired...finally
    Use handrails while using steps. If you haven't learned this already, lenses with larger vertical sizes work better for both distance and reading. Get a copy of your RX and order glasses online. I use Zenni and am 100% satisfied.
    I've been wearing progressive bifocals for 30 years and it did take a few days to go up and down steps without feeling like I was going to trip and fall.
    Wynnded and Solid Snake[OP] like this.
  6. Jul 27, 2025 at 1:21 PM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    Yeah, I was worried that my frames didn't have enough vertical real estate for progressives, at least not for a newbie like me. They're only 35.3mm tall. But, I just want to get used to them before I buy another set with different frames. Since wearing glasses, I've become an Oakley fanboy. That's my current frames, and will be my next frames, just a different model with a little more vertical size.
  7. Jul 28, 2025 at 8:52 AM
    snoope
    snoope The Old Man
    I only wear mine for driving as prescribed....
    Can not wear them to read as some have stated, blurry looking down towards your nose full time..
    I have mine because my Sugar was raising hell but now that is under total control my site is back to 20/15 ...
    Good luck with them and PLEASE listen to your body.... Took me arriving at 60ish to learn this o_O:thumbsup:
    Wynnded likes this.
  8. Jul 28, 2025 at 9:05 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x2 on this... @Solid Snake
    I scan w/my eyes A LOT; in lieu of pointing my head (nose or whatever) at what I'm trying to see... I tried them for a while and just couldn't get them to work for me. I about killed myself going down some stairs one day cuz I 'glanced' down, and the 'zoom' screwed up my depth perception.
    My wife on the other hand loves them and adjusted to them almost immediately. She, on the other hand, moves her head a lot as she's looking around up and down, etc...
    I will say this though.... The Oakley Holbrooks have a large lense area, but fit well on average sized faces/heads. The bulk of the lens sits below eye level. I have them as a prescription distance sunglass, and they are phenomenal. If you end up trying to do a larger lens w/progressives, you can basically have your entire 'line of sight' portion of the lens for distance and the reading portion at the bottom forcing you to really scan downward to pick up the reader portion.
    However, with all that being said, I think if you find yourself a 'pointer' when it comes to scanning progressives will work, but if you through all vertical planes and scan horizontally as well, you'll probably always struggle w/progressives.
    Wynnded likes this.
  9. Jul 28, 2025 at 9:41 AM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    Yes, I am learning that I need to move my head rather than just my eyes to scan. I'm getting used to it though, I think these may work out. Just need to order something a little bigger, like I said.
    Mdl and Tripleconpanna[QUOTED] like this.
  10. Jul 28, 2025 at 10:42 AM
    I'm going back to single lenses too. Up close I have my glasses off anyway.
    Mdl and Tripleconpanna like this.
  11. Jul 28, 2025 at 10:51 AM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    I need correction for distance and up close. Up close isn't too bad, but its just going to get worse over time. Might as well get accustomed to multifocal lenses now. That's my thought process anyway.
    kirkb likes this.
  12. Jul 29, 2025 at 5:38 AM
    Kung
    KG, VA
    I went out of my way to *not* get progressive lenses. LOL That said, my case is a bit different.
    I'm farsighted slightly in my right eye; and nearsighted in my left. Both have a slight astigmatism. With that said...while neither condition is terrible, the nearsightedness in my left eye is worse than the farsightedness in my right eye.
    TL;DR: I don't need reading glasses. I DO need distance glasses for driving, watching TV, etc. So I just bought glasses to essentially correct the nearsightedness and such, and added polarization/transition stuff, blue light blah blah. I'll likely get >1 pair of glasses in the future, unless I find it to be a huge PITA to switch out glasses constantly.
