I installed an AMP power step on my Tundra today.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Massivehoodorn, Mar 12, 2021.
  1. Mar 12, 2021 at 4:35 PM
    Massivehoodorn
    Massivehoodorn [OP] New Member
    Joe
    03 extended cab Tundra
    Chrome bar steps, Dual chrome pipes, Pioneer FH-X700BT sound
    Does anyone know which wires sense the doors opening?
  2. Mar 12, 2021 at 10:36 PM
    primeiro
    primeiro New Member
    Henk
    Netherlands
    i know it is somewhere here on the forum , try and use the search button .
    i have seen it come by 3 or 4 weeks ago with diagram and all
    Saltyhero13 likes this.
  3. Mar 12, 2021 at 11:29 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  4. Mar 13, 2021 at 4:57 AM
    FLG8R71
    FLG8R71 New Member
    Jax FL
    2019 Voodoo Blue TRD Pro
    Other than using butt splices instead of Positaps these are the instructions I used when I installed my steps. I see that you drive an 03 and these directions list 2007 as the earliest year but including the link anyway as maybe it'll help. Good luck on getting it figured out as they are a great product.
    https://www.amp-research.com/images/ePIM/original/AMPIS-75137.pdf
  5. Mar 22, 2021 at 7:58 PM
    Massivehoodorn
    Joe
    I finished my install no thanks to the lack of intelligent prints from the supplier. They must have gotten rid of the one man that could include up to date wire connections. I retired after 40 years as an electrician, that became my handicap when they never included any prints or even the mention of where these connectors might be located on a new Tundra. Watch out for ANY wires that might wind up getting caught in the risers. I also used sheet metal screws to secure the motor covers. Worked like a charm. Any other questions I will try to answer but be specific, please.
  6. Apr 10, 2021 at 6:28 AM
    Glennjc1978
    Glennjc1978 New Member
    Glenn
    2021 trd pro lunar rock
    The steps are well worth the money for sure.Gives it a clean look.
  7. Apr 10, 2021 at 5:59 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Agreed, I had these on my Tacoma and an saving up for a set on the Tundra. Hopefully soon!
  8. Apr 11, 2021 at 6:41 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    A few tips...
    Put the boards on the brackets right before you put the fuse in to check operation, not early in the process per the instructions. You're doing most of the work in that area and they're in the way.
    Paint the holes you drill for the LED grommets. Don't try to drill through a spot weld.
    Put some RTV on the motor covers when installing.
