I had no luck searching, loose drivers seat driving me crazy
Discussion in '2.5 Gen Tundras (2014-2021)' started by Seafury, Apr 16, 2020.
  1. Apr 16, 2020 at 4:05 PM
    Seafury
    Seafury [OP] Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    I searched, I really did.
    I found zero threads on this issue.
    2014 1794 4x4 56k miles.
    Drivers seat rocks, not slides, rocks 1/4 - 1/2in every time I accelerate or brake. REALLY annoying the crap out of me.
    I have looked under the seat, and tried to move it by hand when not sitting in it and I can't really replicate the movement or see anything amiss.
    Does anyone have experience with this issue that can point me in the right direction?
    Thanks in advance to the best Tundra forum people on earth!
  2. Apr 16, 2020 at 4:33 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Mine did that.. After I pulled it out and put it back in to install a stereo it quit? Bolts were tight beforehand so I can’t say for sure what it was but it’s gone now! 2013 RWDC
  3. Apr 16, 2020 at 4:35 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Obviously sounds like a loose bolt. Can you see all 4 of the nuts are tightened at the floor? The other thing you might check is the slide where it attached to the frame of the seat. I had a car, after an accident, the driver seat wobbled like that, it was because a seat frame weld broke it was a fun drive home. They totaled the car so I never got it fixed.
  4. Apr 16, 2020 at 6:43 PM
    Seafury
    Agent K
    SC Low Country
    Thank you for the suggestions everyone.
    Nothing is visibly loose, especially not the 4 main floor bolts.
    There is no popping or resistance, it just smoothly rocks back and forth.
    Guess I will have the wife (100lbs less than me) or someone, sit in it and rock it while I look under. If that doesn't show me something then it will have to come out for a thorough look over but that won't be fun lol.
    I will let yall know what I find when I get a chance to look at it, maybe this weekend.
    NewImprovedRon likes this.
  5. Apr 16, 2020 at 6:47 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    It doesn't take long to unbolt the seat and check that it's positioned in the mounts correctly. Taking the covers off the back legs is probably the most tedious, but a pair of linesman's pliers on the clip will help you push those out.
  6. Apr 17, 2020 at 6:40 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    You probably have done this... but have someone sit and see if the back of the seat rocks separate from the base. Maybe some internal framing is loose or broken. You know, Like if someone sitting in back seat pushes the seat back with their feet... been known to happen.
  7. Apr 17, 2020 at 6:53 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    If it is just the back rocking then I dont think your fixing that. If your talking the whole seat, then yea pull it out and have a good look. Are the track to seat bolts tight, or is the locking Claw worn out or mising a spring or something.
