I drove 50 miles home, towing my boat, in 4WD Hi, how much damage did I do?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Long Duck Dink, Jul 28, 2023.
  1. Jul 28, 2023 at 8:40 PM
    Long Duck Dink
    Long Duck Dink [OP] Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Long story but pulled my boat out of the lake and had to use 4WD Hi because the tires were slipping on the ramp
    Completely forgot to disengage after wiping down the boat and drove home for 50 miles without realizing I was still in 4WD Hi. I could tell something was slightly off with some of the driving characteristics but didn't look close enough at the dash and I completely forgot about what I'd done.
    Finally realized driving up my hill but by then I was almost home and it was too late.
    How much damage did I do?
    What can/shoudl I do to make things rights (if anything)?
    Mr Badwrench likes this.
  2. Jul 28, 2023 at 8:42 PM
    Just pretty much all straight? If so, ur fine. You’ll feel binding if it was sharp turning
    Metro14536, ColoradoTJ and Casper421 like this.
  3. Jul 28, 2023 at 8:45 PM
    Long Duck Dink
    North Salt Lake, UT
    Not all straight, some straight. We had to wind through a canyon and I had to do some tight turning in a parking lot to get gas.
    I felt some binding but it didn't occur to me until I started wondering why I was having such a hard time going over 65 mph.
  4. Jul 28, 2023 at 9:10 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Weakest link are the CV axles. If you didn’t break ‘them then you’re fine.
    FirstGenVol, Jaypown, Bprose and 4 others like this.
  5. Jul 28, 2023 at 9:24 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    This here. If it drove home and nothing broke, you're good to go.
  6. Jul 28, 2023 at 9:45 PM
    Casper421
    In the woods
    06 DC
    Should’ve had enough weight on the tongue that the front didn’t take too much abuse. Should be fine. Drive around the block in 2wd and see if you hear anything odd. Chances are you won’t.
  7. Jul 28, 2023 at 11:54 PM
    I have done the same thing. Nothing is ever 100%, but like the others have said...you good.
    NewImprovedRon and ATV25 like this.
  8. Jul 29, 2023 at 12:09 AM
    Aerindel
    Aerindel New Member
    Montana
    Probably none. Certainly none while going straight or mostly straight.
  9. Jul 29, 2023 at 12:59 AM
    18" TRD Off Road Wheels
    Previous comments are pretty much covering it. If you're super worried do a fluid change in the transfer case for peace of mind.
    A tip to avoid it in the future: when pulling the boat up the ramp, or using 4WD for any low speed stuff, pop it into 4Lo. It'll drag it out way easy, and there's no way you can forget with it in Lo.
    Another thing, if you are backing into the water you may want to do the rear diff breather mod if you haven't already.
  10. Jul 29, 2023 at 3:35 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I did it once when I had my boat parked on wet grass. I put in I 4lo to avoid tearing up my yard. I could not believe that I did not notice when making a sharp turn out of my driveway. My boat weighs 5000lbs so I figure there was some weight off the front end. Probably 30k miles ago and no problems.
    Long Duck Dink[OP] and ATV25 like this.
  11. Jul 29, 2023 at 6:29 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    My friend in high school drove their Ford Ranger around in 4LO for a week or so. It wasn’t until I hopped in a noticed we were bouncing off the rev limiter at 50 MPH that they left it in low range.
    “What’s going on with your truck?”
    “I dunno, it’s been doing this for a week.”
    “You’re in 4LO, put it back to 2HI.”
    Truck was fine, it was funny. It was a good lesson for both of us on part time 4x4.
  12. Jul 29, 2023 at 7:21 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    This sounds like something my son would do......" I dunno but I kept driv8ng it because......independence " :facepalm::rant:
  13. Jul 29, 2023 at 9:25 AM
    Long Duck Dink
    North Salt Lake, UT
    I appreciate the shared experiences and the re-assurances that I'm probably OK. You're all probably right. I drove it this morning, 2WD, and there doesn't seem to be anything wrong and no strange noises or differences in driving behavior than before I made my stupid mistake.
    Lesson learned! Thanks again!
    GODZILLA and T-Rex266 like this.
  14. Jul 29, 2023 at 9:29 AM
    Mr Badwrench
    Mr Badwrench New Member
    You aren't the first person to ever do this, and you certainly won't be the last. I'm sure your truck is fine. You would know by now if you damaged something.
  15. Jul 29, 2023 at 1:50 PM
    Rdrcr
    Rdrcr New Member
    2019 Toyota Tundra TRD Sport
    Wouldn't worry me at all.
    snivilous and Long Duck Dink[OP] like this.
  16. Jul 29, 2023 at 2:25 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Change the fluid
  17. Jul 29, 2023 at 2:25 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Wouldn't be remotely worried.
    Long Duck Dink[OP] likes this.
  18. Jul 29, 2023 at 2:40 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Maybe just change your gear oil if worried
