I don't want a cab leak. Back glass rubber corner detached
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ArdnuT trd, Sep 27, 2021.
  1. Sep 27, 2021 at 1:01 PM
    ArdnuT trd
    ArdnuT trd [OP] New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    hey guys I did a pro grill swap on my 21 mgm I bought everything from the dealer but the garnish piece although clipped in wiggles like its loose is there some way to tighten it? Did I get a bad grille or garnish. I went up to it and tried to move the garnish on a 21 lunar rock and it feels definitely more secure. I just don't want this garnish popping off because it is pretty pricey.
    And lastly the back bottom corner square shaped window rubber piece has torn free in a corner. I don't want a cab leak. Is this a warranty item? Hate to have to replace it with it being so new.
    Thank you guys for your help.
  2. Sep 27, 2021 at 2:12 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    It was the same for me with my grille swap. The garnish snapped in but wiggled considerably. I actually put a bit of adhesive in behind it and now it's solid.
    Is it possible for you to post a picture of your window issue? If it's what I am thinking it is, then I would say yes your dealer ought to be able to fix it under warranty.
  3. Sep 27, 2021 at 11:37 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    With a 2021 truck I'd be at the dealer getting both of those items addressed... under warranty.
  4. Oct 12, 2021 at 5:02 PM
    ArdnuT trd
    Blake
    Yeah I'll post a pic were you aware the pro grille actually requires two retention washers that a lot of how to's and videos fail to mention? I have the part number if you need it
