I DIYed the infamous cam tower leak...
Discussion in '2nd Gen Tundras (2007-2013)' started by CoreyF, May 20, 2023.
  1. May 20, 2023 at 2:26 PM
    CoreyF
    CoreyF [OP] New Member
    Corey
    I decided to tackle the cam tower reseal myself on my 2011 toyota tundra with the 5.7
    Mine was leaking a quart about every 300 miles with 171k on the odometer which is excessive in my opinion.
    I was going to make a DIY video on this repair; however, I only recorded the removal and not the installation. This is because by the time I got in there, for one, I realized how ridiculously long this video would need to be. Second, it was very difficult to show everything I was doing. Third, I did not feel like a figure of authority on this repair since I had never done it before. And finally, I realized... This repair really shouldn't be presented as one for just any DIYer. There are a lot of very meniscal mistakes that could result in blowing up your engine.
    I did it in the truck without pulling the cab or the engine. I will say it was quite the bear of a job. Now, I am a full time mechanic and I do have a lift at my house, so I do have those things going for me. But I had never done this repair before and did not know what to expect. Overall I'd say anybody who is proficient at working on cars could do the job, but it may be worth it for most DIYers to just pay the dealer. The job took me a total of about 20 working hours to complete. The most difficult part was finding all the seals from Toyota...
    Tips that I have for anybody looking to do this job OR doing valve covers or chains. Avoid as much as possible prying up the valve covers unevenly. They are located on pins and you can easily snap either the valve cover or cam carrier if you force them up from one corner. Another recommendation for the valve covers - GET THE OEM SEALS. I had a Fel-pro valve cover gasket set and the seals were COMPLETELY wrong aside from the valve cover gasket itself and the spark plug tube seals.
    Here are the OEM part numbers for those seals:
    11159-0S010 - you will need 2 of these
    11159-0P010 - you will need 4 of these
    90430-A0001 - you will need 4 of these
    My other suggestion is before you remove the timing cover, ensure that you have ALL of the seals needed. You will need 1 or both of the O-rings for the water pipe behind the water pump depending on how it ends up coming apart. Then most importantly you will need the oil pump inlet and outlet seals. If you do not replace these you may grenade your engine. In addition, you will need the O-rings for the oil filter housing where it bolts up to the timing cover.
    I do not have OEM part numbers to give for these as I got them in a Fel-pro conversion gasket set.
    If you do re-seal your own cam towers I strongly suggest doing the complete chain set with guides and tensioners or at a minimum replace the tensioners as there will never be a better time to do so.
    If anybody would like me to edit the footage of the removal and upload to Youtube I may do so.
    Additionally, if anybody has any questions feel free to ask.
    Here are the pictures I took along the way (the pictures uploaded in the opposite order, look from the bottom-up):
    348365012_1231338524177854_1615083879941076601_n.jpg 346114551_978900349957896_1257457433046369974_n.jpg 348366141_2203891996472850_1974894966559962544_n.jpg 348366979_1320571432149425_4194024155789586093_n.jpg 348361427_641520107373635_4537817532699798514_n.jpg 346104748_626010106234907_2755709749320244685_n.jpg 346105160_282683517429858_785805225002799863_n.jpg 346162470_3472170173022646_1326292103536096309_n.jpg 346147276_1441505693328439_822313694533823893_n.jpg 346105253_779432873579741_8423777488018166937_n.jpg 348380480_590468013151773_668074532247711663_n.jpg 346150693_618754416862622_6335889160708258298_n.jpg
  2. May 20, 2023 at 2:27 PM
    CoreyF
    Corey
    OK the pictures uploaded in a completely incorrect order. Sorry.
    Wynnded likes this.
  3. May 20, 2023 at 2:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Nice job. 20 hours is damn good for a first time, I've heard Techs who do this on a regular basis taking between 11 to 13 hours to complete.
    Trooper2 and CoreyF[OP] like this.
  4. May 20, 2023 at 2:49 PM
    I do believe this might be a first on here. At the very least, I can say I've never stumbled across anyone else who has done this job, so hats off to you for that! If you get a youtube video up for it and it can function as a guide for people, that would be awesome. Possibly even worth a sticky in the 2nd and 2.5 Gen sections.
  5. May 20, 2023 at 3:57 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Bravo! Quite the undertaking.
  6. May 20, 2023 at 4:18 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Great job!!!
    Beautiful clean engine inside.
    Mobile1 oil?
    Trooper2 likes this.
  7. May 20, 2023 at 4:25 PM
    CoreyF
    Corey
    Thank you, sir. I may get another shot one day if a customer comes in complaining of an oil leak on one of these lol. Maybe then I can try to get a better time :rofl:
    Trooper2 and Tripleconpanna like this.
  8. May 20, 2023 at 4:26 PM
    CoreyF
    Corey
    Oh boy I did not know that! Maybe I should have done a better job documenting it. I will see what I can scrape together from the footage I have.
    Trooper2 and GODZILLA[QUOTED] like this.
  9. May 20, 2023 at 4:27 PM
    CoreyF
    Corey
    To be honest I was hoping it would be a little bit cleaner but I can't complain. I do not know what oil had been used prior to my ownership as I just bought the truck in April. But I will say that I did put Mobil1 in after this repair!
    Trooper2 and Piki[QUOTED] like this.
  10. May 20, 2023 at 4:32 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Hats off :hattip:
    That job is way, way, way above my pay grade, skill level and patience... Great work!!!
    BTW, do you have any idea what a dealer is currently charging to complete that job? I'd imagine $2-$3k :notsure:
    Trooper2, CMikeB and GODZILLA like this.
  11. May 20, 2023 at 4:35 PM
    Back in 2022 this guy was quoted over $4K. https://www.tundras.com/threads/cam-tower-leak.110003/#post-2839208
  12. May 20, 2023 at 4:43 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    So, nobody's ever tried to just JB Weld it from the outside? :burp:
    j/k, don't try that. :rofl:
    Kudos to OP, not an easy job from what I understand! :thumbsup: Hope I get lucky and never have to deal with it.
  13. May 21, 2023 at 5:38 AM
    CoreyF
    Corey
    Hey I mean if the cam carrier and the cylinder head were one piece in the first place this would have never been an issue... I think you may be on to something.
    Jernik[QUOTED] likes this.
  14. May 23, 2023 at 6:53 PM
    Richie Rich
    Richie Rich New Member
    California
    07 Crewmax Limited TRDOR.
    Coilovers, wheels, 35s, Amp steps, Carplay
    The thought of cleaning the crap out of the offending area and applying RTV has crossed my mind.
    Unfortunately my truck has this. It isn't excessive but it is for sure doing it. I have been deep into engines before but I really, really do not want to tackle this job so I am dreading writing the check for it.
  15. May 23, 2023 at 7:07 PM
    TILLY
    Massachusetts
    If I ever get the dreaded leak, I'm definitely trying this first. Clean and press into the gap. If it continues to leak, you're out like ten bucks.
  16. May 23, 2023 at 7:31 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Good job. Would you mind giving us a ballpark of what you spent to do the job yourself?
  17. May 27, 2023 at 9:50 AM
    CoreyF
    Corey
    So with all the parts including water pump, belt, chains/guides/tensioners, belt tensioner, belt idler, all of the gaskets, FIPG & PS fluid, oil & coolant I spent around $800
  18. Sep 4, 2023 at 11:21 PM
    Nemesis
    Nemesis New Member
    Is this a cam tower leak? If so, would you consider this excessive?
    I'm no mechanic and my mechanic skill level is on the intermediate level but I fear I have no choice but to tackle this myself. On a tight budget.
    But the question to you is, do I really need to have this done? Meaning, will this ruin my 5.7 engine if I don't fix it?
  19. Sep 5, 2023 at 5:33 AM
    CoreyF
    Corey
    To me that looks more like it originates from your timing cover. To check your cam towers remove the little access covers in your wheel wells (they're held on with like 4 plastic clips each) and look above the exhaust manifolds. Identify the plate below the valve cover and you will see RTV sealant where it mates with the head. That is where you will be able to tell if your cam towers are leaking. And to be honest with you my friend, if its not dripping on the ground and you don't smell it on your exhaust I don't think I'd bother fixing that at this time.
    Xcumminsguy likes this.
  20. Oct 19, 2024 at 9:57 AM
    swtrader
    swtrader New Member
    Please (anyone/everyone/Corey) - This is wayyyy beyond anything I could do. Dealership says cam tower is leaking - when I had it in for a brake job. I am very retired. I drive it 300-500 miles per month. It seems to ‘use’ about a half quart every 1-2 months. I am over-protective,perhaps, changing Valvoline FS 0-20 every 3-5 months. I do not see an obvious leak but there is some slight oil indication on the passenger side.
    Given:
    1) limited use (but might want to take it on a 1500-2000 mile road trip);
    2) dealer wants ~$3700 to do the work
    3) I have never had - in 60 years of driving (full license and ‘46 Chevy as first car) - that I like anywhere near as much
    4) while I could leave the cash in my retirement fund for the grandson, $4,000 is something I can handle…
    Is there any harm in doing nothing now but watching the oil stick over time to see if it makes sense?
    thanks for everyones’ input. I do not know what I don’t know.
    Swtrader in DFW
    2011 TRD RWD 5.7 107,000 miles
  21. Oct 19, 2024 at 10:01 AM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Can you take any pics of the leak? I had cam tower leaks on both of my Tundras, but never lost any noticeable amount of oil between oil changes (usually every 6-12 months). I'm wondering if there's another leak somewhere, or if your truck just likes to burn oil (which I don't think is common on these trucks).
  22. Oct 19, 2024 at 11:06 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    That's not too bad for a trip. You can monitor it and try 5w-30 oil instead of the 0w-20. I run a light 5w-40.
    Terndrerrr likes this.
  23. Oct 19, 2024 at 8:42 PM
    swtrader
    swtrader New Member
    Buck. - thanks!
    Best pics I could get with my iPad. I have a Depstect (sp) horoscope I used mostly for in-wall looking. That video did not look too revealing.IMG_0170.jpg IMG_0167.jpg IMG_0167.jpg IMG_0166.jpg IMG_0165.jpg IMG_0164.jpg
  24. Oct 19, 2024 at 9:18 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Jump to post #38 and 43 on this thread and it will give you a good idea where to check for cam tower leak.
    BuckWallace likes this.
  25. Feb 5, 2025 at 12:21 PM
    You can’t park there
    You can’t park there New Member
    2019 Tundra SR5 CM 4X4
    Fox 3” lift w/ Icon leaf Alpine Halo HU Katzkin leather upgrade
    Here’s a photo of where my leak started (80,000mi) driver side- directly behind AC compressor. 3way corner between timing cover/block/head …check out you tube “the car care nut” fixing every tundra problem.IMG_4920.jpg IMG_4923.png
  26. Feb 6, 2025 at 3:32 PM
    Dr_Al
    Dr_Al New Member
    Al
    Unless it was leaking on the exhaust header I wouldn't bother. I guess if I parked in a clean garage and didn't like seeing cardboard under the truck to catch the oil it might push me into fixing it as well. But I come from a time when engines leaked oil. My 77 Corolla had round seals around the valve cover (tubes that went around the spark plugs) that would fill up between oil changes. That kind of sucked because you couldn't get a lot of the oil out before removing the plugs. So oil always ended up in the cylinders and even after turning the engine over to blow it out it would smoke like crazy for a few miles. Machining of engines has advanced so much since then. Now people just expect perfect. Not saying that's bad but $4k is quite a bit of money. I would do the work myself so it's the 15 to 20 hour part that would bother me.
