I did it. Broke my oil filter housing
Discussion in '2nd Gen Tundras (2007-2013)' started by D4x4TRD, Feb 16, 2023.
  1. Feb 16, 2023 at 9:01 AM
    D4x4TRD
    D4x4TRD [OP] New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    Went to go change my oil this morning thinking I drank enough coffee. Go to change the oil on the 2012 tundra and I guess I wasn’t awake. Didn’t take the drain plug out first. Started wrenching on the filter housing with the filter adapter. One of the edges on the adapter punched a hole in the side of the housing. Got it off and then the light bulb lit up. Why didn’t I take the drain plug out first. That thing was on there tight. Got it replaced with a metal one. Hopefully that prevents my mishap next time. Just wanted to share the experience. Thanks you all. Everyone have a great day
    bulldog93 likes this.
  2. Feb 16, 2023 at 9:31 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    won't have helped. Don't beat yourself up too bad. In my experience its only draining oil in the filter. Oil pan is opn to atmopshere. I don't believe its pressurized after you shut the truck off.
    D4x4TRD[OP] likes this.
  3. Feb 16, 2023 at 9:44 AM
    D4x4TRD
    Định
    Va beach, VA
    Thanks. I was hard on myself because I’m pretty sure it was me who tightened the housing last oil change and I didn’t think I had tightened it down that much. It was on pretty darn tight. Haha. Oh well . Live and learn.
  4. Feb 16, 2023 at 9:53 AM
    Did you swap over the center tube? Some people didn't do that when they changed theirs.
  5. Feb 16, 2023 at 11:05 AM
    D4x4TRD
    Định
    Va beach, VA
    I bought it and it’s new so why not. Yes I did switch the new one. Thanks for the reminder.
    NewImprovedRon likes this.
  6. Feb 16, 2023 at 11:14 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    It's a plastic to aluminum connection. Hand tight plus a 1/4 turn still runs the risk of "holy crap this thing is almost impossible to break loose."
    The swap out to an aluminum to aluminum connection is the answer. Including the old school (relatively speaking) Jowett aircraft aluminum. :)
  7. Feb 16, 2023 at 11:18 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I actually like the idea of the fumoto valve on the housing but i guess it wouldnt work with the oem one with the oil wrench
  8. Feb 16, 2023 at 11:24 AM
    D4x4TRD
    Định
    Va beach, VA
    Doesn’t look like the oem adapter would work with the fumoto. But the fumoto would definitely be a lot cleaner process.
  9. Feb 16, 2023 at 11:52 AM
    AZBoatHauler
    So.Arizona
  10. Feb 16, 2023 at 12:00 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
  11. Feb 16, 2023 at 12:03 PM
    MadMaxCanon
  12. Feb 16, 2023 at 1:09 PM
    D4x4TRD
    Định
    Va beach, VA
    Well dang. Problem solved. Awesome. You got me stumped on the thread size.
  13. Feb 16, 2023 at 1:12 PM
    D4x4TRD
    Định
    Va beach, VA
    That oil filter wrench makes more sense than the one I got.
  14. Feb 16, 2023 at 2:47 PM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    When I bought my Tundra the first thing my buddy warned me about was the filter housing and how he destroyed his the first time he removed it. The dealers apparently put them on way to tight. Not sure if the housing is a special size but it seems best to use the Toyota OEM removal tool. Others tools I had were close but do not fit exactly. I bought the oem one and the first time I changed it the housing was incredibly tight. I had to get my long breaker bar to get it to turn. Since then I just snug the thing up and give a bit more with the wrench but certainly not a 1/4 turn. I don't think that thing is backing out even if hand tight.
    As to the drain plug in the bottom. I found using a hose on the device to open the valve ends up causing me more of a mess than just having the pan under it and shoving it up in the hole. I just use the plastic one that comes in the filter box.
    The first time I change the oil in my Tundra it looked like a kid did it I had so much oil on the floor. After 3 time doing it, I finally have it down without too much spillage. I still think that other MFG have better systems where the paper oil filter is removed from the top under the hood. Personally I think the metal screw on kind are easier than these paper things. I know there is an adapter but its not worth the money to me.
  15. Feb 16, 2023 at 3:12 PM
    D4x4TRD
    Định
    Va beach, VA
    Yep. I had to put the breaker bar on it to get off. I don’t think there’s a way to avoid it getting that tight besides not over tightening of course. And I changed the oil myself last time. And I know not to overtighten. But it sure was a bear to get off. My adapter I bought from the auto store was specifically for the tundra. It seemed to fit snug. But it might have been just enough to puncture that hole along with the pressure of taking it off.
  16. Feb 16, 2023 at 4:52 PM
    dhalsey
    dhalsey New Member
  17. Feb 16, 2023 at 7:50 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Shit! Let me say I can relate...
    PO of my 2010 never touched a wrench, took it JiffyBoob and those monkeys appear to have tightened it to 550Ft/lbs... I seriously thought I was going to break the neck off the oil pan section on my first oil change. It was an awful feeling for our first tango below!
    I thought to myself, its an O'ring into a tapered housing, it only NEEDS to be TIGHT enough to NOT FALL off in the next 5000 miles! lol
    As for using a quick drain plug on the filter housing, are they rated for peak pressure spikes of 120 PSI? Granted, most are a ball valves and can handle it but most are intended for the oil pans (low pressure) verses a live oil feed with varying pressures throughout the hour.
    JM2C - that is not worth the risk unless the device is rated to 250 PSI surges....
    Edit for clarity
  18. Feb 16, 2023 at 8:58 PM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    It happened to me too on the first oil change on my new to me truck and also my wife's 4runner. Both of them were overtightened by the same Toyota dealership we bought them from. I had a hell of a time getting both of them loose and ended up having to resort to an impact to get the tundra one off. And of course one of the tabs broke off in the process, leaving a big hole in it. I wasn't at all surprised it broke though, ya know since I had to use an impact on it. I was kind of in a panic since this happened on a Sunday and all of the parts stores around me said out of stock on the dorman replacements. I called one of them and they happened to have one in stock even though their inventory showed zero. That was a relief.
    Didn't have to use an impact for the 4runner but it still broke in the process of removing it, even though I had all of the tabs lined up correctly on the filter wrench. the force I had to put on it was way more than the plastic was designed for. Already had a replacement in hand just in case.
    I just snug it and easy to get off. No leaks either after several oil/filter changes later.
    NewImprovedRon and D4x4TRD[OP] like this.
  19. Feb 16, 2023 at 10:11 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Oh, I have i got that with a funnel and the filter wrench...just did an oil change with the clear tubing, I had frickin oil pissing down my arm all over the place...never had so much fun changing an oil filter on any vehicle...kind of makes me want to modify existing setup to spi n on filter. What a pita Toyota !!!
  20. Feb 17, 2023 at 9:08 AM
    KeepOnTruckin
    Randy
    PS WIX filters come with a little plastic spicket to direct the drain straight down, it seems to work well.
    And for any NAPA shoppers out there, NAPA rebrands WIX filters so they have them there too.
  21. Feb 17, 2023 at 10:22 AM
    D4x4TRD
    Định
    Va beach, VA
    Sounds exactly like my experience. I’m happy knowing I’m not the only one.
  22. Feb 17, 2023 at 10:24 AM
    D4x4TRD
    Định
    Va beach, VA
    Looking back I realize my filter came with the little plastic drain tube too. I just had a total brain fart and skipped that step. Even though I knew.
    KeepOnTruckin[QUOTED] likes this.
  23. Feb 23, 2023 at 12:41 PM
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    2012 Tundra Overland Build
    I feel you, same thing happened to me when my first time trying to change oil on the truck by myself, it didn't come out till I borrowed an impact gun from a neighbor and heated it up.
  24. Feb 23, 2023 at 12:49 PM
    D4x4TRD
    Định
    Va beach, VA
    Wow. That’s tougher than my situation was. Happy to hear you overcame the situation too.
    Harold_Z likes this.
  25. Feb 23, 2023 at 3:28 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
  26. Feb 23, 2023 at 4:10 PM
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    Do you have the plastic housing or the aluminum one?
  27. Feb 23, 2023 at 5:30 PM
    PhotoNerd
    Tony
    Waterford, CT
    I currently have the plastic housing... The last oil change the drain wouldn't loosen and so I had to remove the filter housing without draining it and it was a huge mess.
  28. Feb 23, 2023 at 5:37 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Find an oil filter housing cap that has a built in Fumoto valve. Its the bees knees and makes things easy.
  29. Feb 23, 2023 at 5:37 PM
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    I feel you, even with the plastic drain tool provided in the filter, I still make a mess sometimes.... The plastic thing wouldn't stay on and did not come off easily sometimes...
  30. Feb 23, 2023 at 6:07 PM
    Roborob70
    Robert
    Golly wally, your realyl showing your age with that one...Bees Knees. Shit heard that from one of my moms friends she was pushing early 80's and this was years ago.
