I couldn't disconnect outer tie rod.
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Dec 29, 2023.
  1. Dec 29, 2023 at 4:40 AM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I was going to try and replace my lower ball joints, but I couldn't get past the very first step, disconnecting the outer tie rod.
    I watched all the videos, and they made it look like all I had to do was remove the 24mm nut and give the knuckle a few whacks with a hammer and everything would disengage.
    I just couldn't make anything budge. I used liberal amounts of Blaster PB spray.
    When I started hitting stuff with my 6 pound hammer that I knew shouldn't be hitting I called it a day.
    Luckily, I was able to put everything back together.
    I guess I'll have a mechanic do the job for me.
  2. Dec 29, 2023 at 4:45 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    You need a ball joint separator - you can rent them for free from auto parts store - I had same issue and the separator popped it easily
    NewImprovedRon, myt1[OP] and KNABORES like this.
  3. Dec 29, 2023 at 9:37 AM
    myt1
    Richard
    Scottsdale, AZ
    Perfect, thanks.
    I'm on my way to O'Reilly's to get one now.
  4. Dec 29, 2023 at 9:50 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Make sure you are not pressing the tool against rubber boot.
    myt1[OP] and NewImprovedRon like this.
  5. Dec 31, 2023 at 5:42 AM
    myt1
    Richard
    Scottsdale, AZ
    Thanks so much.
    I rented a ball joint separator from O'Reilly's and it popped apart without too much difficulty.
    The boot was aleady torn, it is 13 years old, and replacing the inner and outer tie rods will be my next job.
    Thanks again.
