I can't figure this out.
Discussion in 'Wheels & Tires' started by Mnorris1206, Jan 2, 2019.
  1. Jan 2, 2019 at 6:05 PM
    Mnorris1206
    Mnorris1206 [OP] Super white is fast as f***
    08 tundra
    So I have a 6" lift on my truck with fuel krank wheels with an offset of +1 with flares but with 35x12.5x18 tires but I want the tire out more can I go as much as a 2" spacer or stay with maybe like a 1.5 ? I dont want to cut anything if possible Also have read if I pull with the truck its not the greatest idea to use wheel spacers ?
  2. Jan 2, 2019 at 6:31 PM
    Mnorris1206
    08 tundra
    Ok I was out cutting the wheel and measuring and for sure I do think thats right I think a 2" would defiantly rub .But you do suggest hub centric right ?
  3. Jan 2, 2019 at 6:38 PM
    Mnorris1206
    08 tundra
  4. Jan 2, 2019 at 7:54 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    I think if you haul your family around that is an unnecessary risk! What if they do snap going down the freeway. All because it looks cooler? I can understand a small spacer on a stock wheel, but you are already running a pretty decent offset not too mention the stress your wheel bearing will see. But to each their own I guess
  5. Jan 3, 2019 at 4:53 AM
    Muleycrazy13
    Buckeye, AZ
    Good most people aren’t as diligent. Enjoy
    Mnorris1206[OP] likes this.
  6. Jan 3, 2019 at 6:39 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I'll weigh in here. I have ran and lightly wheeled with spacers on and have not had issue. Those were Bora brand 2 inch. I have installed some Amazon and Ebay spacers and have had issues with buddies trucks (snapped studs) with just road driving. There is a difference in material quality. Be cautious of what you are buying. The idea of spacers imo if installed and of good quality you should have zero issue.
  7. Jan 3, 2019 at 6:40 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    $100 for spacers and lugs do not scream quality component to me.
  8. Jan 3, 2019 at 6:47 AM
    Mnorris1206
    08 tundra
    I might add real quick I don't dive my truck much. When I do it is pulling a camper . my truck is an 08 with only 82k miles but I may just wait and save and get some negative offset Wheels sometime
