I can hear my tire, what could it mean?
Discussion in 'New Member Introductions' started by Tundragirl16, Feb 24, 2025.
  1. Feb 24, 2025 at 6:02 AM
    Tundragirl16
    Tundragirl16 [OP] New Member
    Lauri
    2016 Toyate Tundra
    New here and new to forums. I need to take my tundra to a mechanic, but I need help telling him what I think the problem is.
    I noticed my 2016 Tundra started to feel like it wasn't driving as smoothly as it used to. I can also hear a noise coming from a tire on the passenger side. Like I can hear the tire (hard to describe) Any ideas?
  2. Feb 24, 2025 at 6:06 AM
    It could be out of balance or it could be a screw, nail, or rock stuck in the tread.
  3. Feb 24, 2025 at 6:16 AM
    Tundragirl16
    Lauri
    2016 Toyate Tundra
    I've looked at all the tires and see nothing. It doesn't sound like a clicking sound. It's more of a hum, hard to explain. I can hear it rotating.
  4. Feb 24, 2025 at 6:23 AM
    Welcome from NY.
    Could it be the rear brake caliper sticking?
    Can you post a picture of the tire showing the tread and a picture looking thru the rim showing the rotor and brake caliper?
    KNABORES and FrenchToasty like this.
  5. Feb 24, 2025 at 6:29 AM
    Tire noise can come from a variety of causes. Common causes for sudden noise would be low tire pressure, a separated belt within the tire casing, or objects or debris stuck in the tire tread. Other causes of rotation noise from a tire that develops over time are usually tread loss related from normal, or unusual wear patterns from poor alignment. A failed suspension part could produce alignment wear overtime. Non-tire related causes include the front wheel bearing, front differential bearing (unusual for passenger side on Tundras) and brake components that contact while driving from warped rotors or sticking calipers.
    Tundragirl16[OP] and Jim LE 1301 like this.
  6. Feb 24, 2025 at 6:38 AM
    enve46
    enve46 New Member
    Andrew
    Hows your alignment? You may have a bad alignment causing the tire to cup. Post some pictures of both front tires for us to further help you. In all honesty, its very hard to diagnose a noise without pics, videos, description of the tires etc etc etc
  7. Feb 24, 2025 at 11:42 AM
    Tundragirl16
    Lauri
    2016 Toyate Tundra
    Thank you for the suggestions. I knew I was reaching when I asked ya'll to diagnose the issue. I do appreciate the feedback that I have received and will get it
    into a mechanic. I drive a lot of miles daily and pick up in small changes.
  8. Feb 24, 2025 at 2:01 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
