I can’t figure this problem out?
Discussion in '2nd Gen Tundras (2007-2013)' started by simp, Oct 26, 2024.
  1. Oct 26, 2024 at 5:32 PM
    simp
    simp [OP] New Member
    So this is very confusing but today I was driving my tundra and hit a decent bump going around 40mph. I saw the traction control light come on and jus thought it was losing traction during the bump. I drive home mostly highway once I get off my traction control light starts blinking and my acceleration is effected. I get home and take it around the block and the abs light comes on as well as the vsc off and 4h light starts blinking. I replaced my wheel bearing earlier that day and the backing plate was rusted so bad that I took off and it crumpled. I replaced the wheel bearing without the backing plate idk if the bump is the problem or I messed up one of the wires when doing the wheel bearing. Please help!!!
  2. Oct 26, 2024 at 6:02 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Maybe ABS sensor?
  3. Oct 26, 2024 at 6:06 PM
    simp
    I checked the abs sensors and did not see anything visibly wrong with them? Why would problem have happened so long after I hit that bump?
  4. Oct 26, 2024 at 6:17 PM
    simp
  5. Oct 27, 2024 at 4:10 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Put another backing plate on it.
    OldGuy03 likes this.
  6. Oct 27, 2024 at 4:19 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Wheel speed sensor
    Probably has collected dirt/ debris on it after install maybe bump jarred some loose
    Anyway I had to replace one of my wheel speed sensors 2 days after replacing my front wheel bearings
    Edit: Everyone will tell you oem I will tell you I have a set of cheepos on the front of my truck for 5 yrs now no issues
    Rockauto $50 for the set
    FrenchToasty and Tundra family like this.
  7. Oct 27, 2024 at 4:56 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Also make sure to clean your battery connections. I dying battery can cause all kind of electrical gremlins
  8. Oct 27, 2024 at 8:59 AM
    simp
    How hard is this job to do mine is a 2007 and is fairly rusty?
    Leo's first[QUOTED] likes this.
  9. Oct 27, 2024 at 9:44 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Super easy. Abs sensor is the wheel speed sensor. Did you pull any codes? A reader will tell you what sensor is causing the problem. If it's the same wheel you just replaced the bearing on could be that missing backing plate...
    I had a bad bearing in a rear wheel this last spring. Code was telling me abs sensor and when I pulled it, it was full of grease and smelled awful. Changed the bearing, cleaned the sensor and perfecto. All was well again.
    FrenchToasty likes this.
  10. Oct 27, 2024 at 9:50 AM
    simp
    Yes since the backing plate is missing and there was probably loose dust in there I think the combination of both of those may have moved or gotten the abs sensor dirty. Also I only have a code puller from auto zone would this be able to pull those codes or do I need something more fancy?
  11. Oct 27, 2024 at 10:00 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    That should work. And your likely right that the jarring hit made the sensor dirty so it's throwing the codes which cause your dash light to come on.
  12. Oct 27, 2024 at 10:26 AM
    simp
    If I pull the bearing off and clean the abs things should return to normal right?
    OldGuy03[QUOTED] likes this.
  13. Oct 27, 2024 at 10:31 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    That's the first step in eliminating it as a problem. You shouldn't have to pull the bearing to get to the sensor though.
  14. Oct 27, 2024 at 10:36 AM
    simp
    Do I just unplug the cable and pull out the sensor it seems to be inside the knuckle.
  15. Oct 27, 2024 at 10:39 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    What year truck do you have?
  16. Oct 27, 2024 at 10:51 AM
    simp
  17. Oct 27, 2024 at 10:58 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  18. Oct 27, 2024 at 11:01 AM
    simp
  19. Oct 27, 2024 at 11:04 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Update. 10 mm bolt. Not the 20 I fat fingered.
  20. Oct 27, 2024 at 1:04 PM
    simp
    The bolt is so rusted I won’t be able to get it off. I’m going to put the rusted backing plate back on would it work to clean it from the inside since I have to take the wheel bearing off anyways?
  21. Oct 27, 2024 at 1:13 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Photos please. Best way to check if tone ring is gunned up is to remove sensor and look into the hole with a flashlight. If tone ring is full of oil or grease it indicates a failed seal.
  22. Oct 27, 2024 at 4:01 PM
    simp
    Update I took the wheel bearing off because the abs sensor bolt was rusted on so bad and to put the backing plate back on. Once we took the the wheel bearing off I could see gunk all over the sensor. Cleaned it off re installed and all lights went away. Next time I install I’ll make sure no loose rust or grime is in there. Thank you all for the help!!!
    OldGuy03[QUOTED] and Leo's first like this.
  23. Oct 27, 2024 at 9:03 PM
    lr172
    lr172 New Member
    07 DC
    I am totally confused. The abs sensor goes into the bearing assembly that you just replaced. How could the nut be frozen, as you had to move both the sensor and the stud to the new bearing assy. Also how did the new assembly get filled with gunk, as it was a brand new part you just installed? The is no grease in that area of the part. Did you replace the axle seal?
    I just did these bearings last week, so fresh in my mind. Frankly i am surprised you got the sensors out. I barely got the first one out and broke the second.
