I’m perplexed. Coolant loss stopping!?!?!
Discussion in '1st Gen Tundras (2000-2006)' started by Redoak, Jul 8, 2025.
  1. Jul 8, 2025 at 5:07 PM
    Redoak
    Redoak [OP] New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I’m confused.
    How long does it take these systems to “burp?”
    Ever since I finished timing belt install, and radiator flush had been adding about a cup of coolant every trip to town and back to keep it to full level; 24-35 miles round trip. (Probably added 1/2-3/4 gallon Since started driving it after replacing everything.)
    Assumed it’s the crossover gasket, or water bypass o-ring not seated good.
    Got all parts coming to replace everything coolant line/gasket related under intake.
    Have about 1K miles since timing belt, radiator flush, and replacement, and after replacing rack bushings this week end, took it out, and really pushed it for first time.
    Past 2 days wife’s been driving it: waiting on coolant maintenance parts to get here for her 4Runner; and if it hasn’t dropped more by morning it won’t have moved in 2 days of driving.
  2. Jul 8, 2025 at 6:31 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    How much have you put it total between top off and initial fill? Is your heater blowing hot? Is your radiator low under the cap or just the overflow? Are you seeing leaking ?
  3. Jul 8, 2025 at 6:47 PM
    Redoak
    Dave
    none
    Since initial fill, and what I thought was top off, 1/2-3/4 gallon about 1 cup at a time.
    Radiator always been full, it was just pulling out of reservoir.
    Heater, and everything works as it should.
    I thought o-ring was leaking because seemed to be more dry antifreeze on the SAIS pump.
    And just looked, and confirmed didn’t loose any today.
  4. Jul 8, 2025 at 6:56 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    And how long ago was the I initial flush refill?
  5. Jul 8, 2025 at 7:16 PM
    Redoak
    Dave
    none
    752 miles ago. 1.5 months ago.
    The largest amount I added was right after running it so hard this past weekend. Which was maybe one and a half cups.
  6. Jul 8, 2025 at 9:23 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Doesn’t sounds unreasonable to think it’s still purging small amounts of air.
    Keep an eye on it over the next few weeks. If it continues to drop then further investigation is needed.
    Redoak[OP] likes this.
  7. Jul 9, 2025 at 3:32 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    1K including highway speeds and you are still having to add coolant? You have a leak. Either externally or internally. No way it takes that long to burp air. Maybe a day or two at most.
    Roblit and Redoak[OP] like this.
  8. Jul 9, 2025 at 6:43 AM
    Redoak
    Dave
    none
    I didn’t think it should take that long
    It’s not smoking. If it was internal loosing that much every 50-75 miles it should be smoking like an old freight train.
    I’m just surprised it has at least slowed down significantly.
    Couldn’t quite tell this morning if it was still at full or not. But Usually level has dropped at least 1” in reservoir after a drive.
    Unless it has stopped It’s on my agenda to go through all hoses and gaskets under intake, on tundra, After I get radiator, water pump, all hoses etc replaced on wife’s 4runner which will hopefully be this weekend if all parts get here when they’re supposed to.
  9. Jul 9, 2025 at 7:15 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    You need to do a pressure test on your cooling system. You could also scope your cylinders at the same time and look for coolant or piston wash which would indicate cooling loss.
    shifty` and Redoak[QUOTED][OP] like this.
  10. Jul 13, 2025 at 9:23 PM
    Redoak
    Dave
    none
    Been a week, and no more loss.
    Changing the water pump on the 4Runner today, got me wondering if it might have been the o-ring lube I used, and it finally cleared out.
    I don’t know. Still perplexed.
    It was permatex but seemed to be more of an oil type i would use on packing a hydraulic cylinder.
    Cleaned it off o-ring on 4Runner just in case and used antifreeze instead.
    TX-TRD1stGEN and The Black Mamba like this.
  11. Jul 14, 2025 at 9:34 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    When you drained your coolant for the work, did you do it by opening the drain valves on the engine block? If so, you may not have tightened them enough. That's what happened to @jpink when we worked on his.
  12. Jul 14, 2025 at 9:55 AM
    Redoak
    Dave
    none
    I checked to see if they were leaking any. Couldn’t find any signs of it.
  13. Jul 14, 2025 at 10:08 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Snug em up with a wrench. I don't remember how obvious it was for him. It definitely sounds like you have a leak though. Unless you just didn't add enough to start.
