Hypertough 23qt Oil Drain Pan (Walmart)
Discussion in 'Product Reviews' started by Getdirections, Jun 1, 2019.
  1. Jun 1, 2019 at 6:06 AM
    Getdirections
    Getdirections [OP] New Member
    2017 SR5 TSS DC 2WD 4.6
    AF011034-1518-4659-9F04-1E0B72D9171E.jpg 471BA77C-407A-4D8F-91BB-897FBFA3A2F4.jpg 6E47B52F-F24B-4689-A8C7-55618C73D4A2.jpg Decided to do my own oil changes to save a few $$ and to make sure it was done right. Can’t recommend this oil drain pan I picked up at Walmart, without reading any reviews, enough!! It says it will hold 23 qts but they are really underselling it. It will in fact hold over 34 Qts as it’s designed so poorly half the oil ends up on the ground!! :mad:
    Really didn’t look at it very closely before using it, the top actually slopes slightly away from the drain holes!!! Splashed oil all over my wheel and suspension and fully half of it ran over the sides and onto the ground. :thumbsup: Got a good mind to return it with the small amount of used oil it managed to catch still inside.
  2. Jun 1, 2019 at 6:09 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  3. Jun 1, 2019 at 6:12 AM
    Getdirections
  4. Jun 1, 2019 at 6:13 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Sucks for sure. Hind site 20/20, studying the pic it looks like the top could easily get overfilled and make a mess.
  5. Jun 1, 2019 at 6:16 AM
    Professional Hand Model
    Hand Protectors
    A 4 gallon bucket works well. Preferably, one with a screw top like used for pool chemicals.
  6. Jun 1, 2019 at 6:20 AM
    Getdirections
    I happened to have a gallon of pour-n-restore I had bought on clearance a few years back. After I soaked up all the oil with cat litter I applied it to the stained area over night. Swept it up and hosed it off... it removed 90% of the stain!! I was impressed! Not sure how it works on older stains but really knocked out a fresh one. Kida pricy tho at $40 a gallon. But $40 vs your wife killing you in your sleep, maybe worth it?
    Sas and Trooper2[QUOTED] like this.
  7. Jun 1, 2019 at 7:07 AM
    Sas
    OKC, OK
    Here's another one. I haven't used it, but this guy seems to like it.
    https://www.garagetooladvisor.com/cleaning/cleaning-oil-spills-garage-driveway/
  8. Jun 1, 2019 at 8:41 AM
    MtMan6698
    MtMan6698 New Member
    Wayne
    Florida Panhandle
    2003 Tundra Limited TRD
    Got one of these. Seems to work OK.[​IMG]
    Taco-Blender likes this.
  9. Jun 1, 2019 at 9:09 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Same here. I dump it before the fluid level gets to the big red drain cap though. I don't trust it not to leak.
