Hypertech Speedometer Calibrator "bricks" randomly
Discussion in 'General Tundra Discussion' started by Spvrtan, Nov 22, 2016.
  1. Nov 22, 2016 at 3:24 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Does anyone else have issues with their kit where every once in a while (like 25% of the time) when you start the truck's ignition it doesn't start completely? What I mean is, the engine will run but the dash will show the ABS/BRAKE lights on and nothing else.
  2. Nov 22, 2016 at 4:54 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I have the answer to solve all your problems ! Had the same issues 3 different units. Easy fix. I am heading out the door for work so I will get back to you tonight when I get home. Sorry bout that..........Talk soon
    joonbug and Spvrtan[OP] like this.
  3. Nov 22, 2016 at 5:14 AM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Haha, that's messed up, could've wrote explanation instead of that
    trayday likes this.
  4. Nov 22, 2016 at 7:31 AM
  5. Nov 22, 2016 at 8:08 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    aw man. that's just wrong.
  6. Nov 22, 2016 at 1:31 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Boooo
  7. Nov 22, 2016 at 1:32 PM
    csuviper
    Broomfield, CO
    I have had the speedo calibrator on for about 3 years. No issues like you describe.
  8. Nov 22, 2016 at 4:51 PM
    CM-LENNY
    San Diego, CA
    Hey Kris I apologize I had to run out the door this AM. I first had dash light issues and gauges not working out in the desert when I hit a whoop-de-do doing about 45 mph and the truck came down pretty hard.The truck also shut off on its own when I hit. I went to restart and the dash lit up light a christmas tree with some random gauges working and others not. Kinda freaked me out on a fairly new truck so I limped back to camp and unplugged the battery, fuses, relays etc and it seemed ok. Trip going home it started again and towing a 8000 lb trailer up the grade with questionable gauges was worrisome. I pulled to the side of the road, tore my dash apart and removed the module and all was perfect. Had hypertech send me another unit and had issues again off and on. They sent me a 3rd unit and I did some research while installing, and tried the unit before buttoning up the dash 100% this time. I wiggled the wires going into the plugs and got the dash to act up. What was happening was the harness from hypertech came with a zip tie holding the wires tight, and when you slide the instrument cluster back into place the wire harness comes in contact with the HVAC ducting and that zip tie would not allow the wires to give at all and would cause the pin connectors to move in the cluster plug. Sorry if this sounds a little complicated or not clear, but it all came down to cutting out the zip tie and that allowed the wires to flex and not create a non connection issue. I guess I could of just said cut a zip tie and be done, but I like to know HOW and WHY things work or fail. Yell if you have any questions.......
    040Tundra likes this.
