hypertech install trouble help please
Discussion in 'Performance and Tuning' started by jsfost, Nov 17, 2017.
  1. Nov 17, 2017 at 9:19 AM
    jsfost
    jsfost [OP] New Member
    So I downloaded the software, updated the module and installed easy 123. Turned on truck and abs/parking brake/ anti skid, lights are on. Removed unit and now the check engine light is on
    dcsleeper408 likes this.
  2. Nov 17, 2017 at 9:25 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Did you try to power it before you mounted back the cluster?
    Check if any damage is on the board. could be faulty..
    Also when you place it behind the cluster make sure nothing is hitting it or pressing on it.
    joonbug likes this.
  3. Nov 17, 2017 at 9:31 AM
    jsfost
    Yes I powered up the truck before installing the cluster and the problem was there. When you ask the if any damage is on the board are you talking about the one the hypertech unit came with. I don’t see any damage. Tried unhooking unit and updating unit on laptop again, and I also tried clear vehicles computer by unhooking battery. Still didn’t work
  4. Nov 17, 2017 at 9:33 AM
    Did you keep a battery charger connected to it while installing?
  5. Nov 17, 2017 at 9:33 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Ooops. Sorry. You are talking about the Hypertech interceptor.. I thought it was the speedo healer.
    So with it off are you able to read the code?
  6. Nov 17, 2017 at 9:34 AM
    jsfost
    No battery charger was used.
  7. Nov 17, 2017 at 9:34 AM
    jsfost
    No it is the Speedo calibrator. Don’t have a code reader
  8. Nov 17, 2017 at 9:34 AM
    It should have been. You can potentially fry your ECU
  9. Nov 17, 2017 at 9:35 AM
    Ok, so not the tune, right?
  10. Nov 17, 2017 at 9:35 AM
    jsfost
    Correct not the tuner
  11. Nov 17, 2017 at 9:35 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yes negative shouldve been removed prior to any installation/removal of the speedo unit.
  12. Nov 17, 2017 at 9:36 AM
    jsfost
    Well crap
  13. Nov 17, 2017 at 9:37 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    as of now. read the code and see what it pulls up. then we can go from there.
  14. Nov 17, 2017 at 9:37 AM
    jsfost
    Followed the directions to a “T” and it never talked about disconnecting the battery. Uh oh!
  15. Nov 17, 2017 at 9:37 AM
    jsfost
    Ok thanks for your help. I’ll get back with y’all.
  16. Nov 17, 2017 at 9:40 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    T-Rex266 likes this.
  17. Nov 17, 2017 at 9:40 AM
    Let us know what the code reads
  18. Nov 17, 2017 at 9:47 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    ahhh you know what might be an issue as well?
    2014-2015 didn't have much issues..
    2016+ started to get some issues.. I think it was with the platinum models or something.. I'll try to find the thread. I remember the newer models had some type of issue before I bought my used one.
  19. Nov 17, 2017 at 9:53 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  20. Nov 17, 2017 at 9:57 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  21. Nov 17, 2017 at 10:40 AM
    jsfost
    Well I really do appreciate all the info. Good posts. I have a 2015, I immediately after getting yalls replies went out and disconnected the battery. I took everything off and put it back to stock. Vacuumed out out truck blah blah, hooked the battery up and everything had cleared. Whewwwew! Thank you for you help I will keep y’all up to date!
    Les7311, 040Tundra, T-Rex266 and 2 others like this.
  22. Nov 17, 2017 at 10:42 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :thumbsup:
  23. Nov 17, 2017 at 11:38 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  24. Nov 17, 2017 at 2:02 PM
    jsfost
    Auto anything. Talked to Hypertech tech support, they seem to think it’s a bad harness.
  25. Nov 17, 2017 at 7:43 PM
    jsfost
    2015/ model#730119
  26. Nov 17, 2017 at 8:39 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You don't need a battery charger with the Hypertech tuner. Its a plug in play system that reads your sensors and adjusts accordingly unlike the BD where it actually installs files to your ECU
    14burrito likes this.
  27. Nov 17, 2017 at 8:42 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Disconnecting the battery for 20 mins or so will reset all the codes. My dash lit up like an xmas tree when I had the Hypertech first installed
  28. Nov 17, 2017 at 8:50 PM
    I know. :DI thought it was the actual tuner like BD before he said it was the HT
  29. Nov 17, 2017 at 9:09 PM
    I’ve never had good luck with Hypertech. What I find that works the best is unplug the unit from vehicle, place on hard counter, use 3 lb sledge hammer and smack it no less than 38.45 times, open trash can lid, place parts in trash can, learn expensive lesson.
  30. Nov 17, 2017 at 9:18 PM
    jsfost
    So boardude, did it eventually go away, or did you have to change out the HT speedo calibrator?
