Hypertech inline speedometer calibrator
Discussion in '2.5 Gen Tundras (2014-2021)' started by PowerUp, May 29, 2020.
  1. May 29, 2020 at 5:56 PM
    PowerUp
    PowerUp [OP] New Member
    2" Lift and 295/65/r20
    Just installed my Rough Country in Speedometer made by Hypertech. Installed per instructions but speed was way off. I had not read post that said use tire height instead of tire size. I had left the cable plugged in to control box to be able to re-calibrate. I recalibrate and was closer but thought I could get closer. On doing so the third time it went back to stock setting. Since then have tried numerous times to correct. Program says that the ratio has been saved successfully. And if you look at it shows the new ratio. However after testing it is still stock setting.
    Any help would be helpful.
    2020 Tundra Platinum
