Hyperflashing Hazards
Discussion in '2.5 Gen Tundras (2014-2021)' started by snogoer13, Nov 18, 2018.
  1. Nov 18, 2018 at 5:39 PM
    snogoer13
    snogoer13 [OP] New Member
    2014 Tundra Limited Crew Max
    Hi Folks,
    New here...first time poster!!
    Quick question on hyper flashing. I installed replacement LEDs for my front turn signals and they now hyperflash. I assume I need a resistor or something along those lines. BUT my question - Does anyone know of a product that would toggle hyper flashing for when I run my hazards but NOT when I use my turn signals? If I had this, and I convert the rears to LED's as well, it means I won't need to by strobes for plowing. Any thoughts? Any advice, suggestions or heckling welcome.
  2. Nov 18, 2018 at 5:52 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Not that knowledgable on your question but im sure someone will be along shortly who can help.
    Thegr8punkin and snogoer13[OP] like this.
  3. Nov 18, 2018 at 5:54 PM
    Welcome from Texas
  4. Nov 18, 2018 at 6:16 PM
    Professional Hand Model
    Hand Protectors
    I’ve suffered from LED rejection before. Switched back to regular bulbs and life was easier again.
  5. Nov 19, 2018 at 1:21 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Welcome, it would be easier to run strobes than try to do that, and yes you need a resistor. What bulbs did you get?
    -Jason
  6. Nov 19, 2018 at 4:00 AM
    Welcome from NY.
  7. Nov 19, 2018 at 4:20 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not sure on yours but my 04 there's a Novita LED compatible flasher so that resistors aren't needed.
    IMO using LEDs is to lower power consumption and if you have to add resistors that kind of defeats the purpose.
  8. Nov 19, 2018 at 6:14 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    The hazards work on a different type of circuit or something like that. It would be better to just to install strobe lights. The resistors are needed to simulate a load that the filament bulb uses. The vehicle detects the lower voltage and causes the hyperflash. I have had LED turn signals and side marker lights in my truck since 2014 when I bought the truck and still have them today.
  9. Nov 19, 2018 at 7:11 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I bought signal LEDs on Amazon (Canada) with built-in resistors. Might be a different story come next summer and they overheat causing hyperflash. Right now so far so good.
  10. Nov 19, 2018 at 8:48 AM
    snogoer13
    Wow - great feedback folks. Thanks so much!!! So it sounds like external strobes are the way to go...I still like the LEDs though, so I'll look for resistors or perhaps the Novita version.
