Hyper flashing signals
Discussion in '2.5 Gen Tundras (2014-2021)' started by BigSwole, Aug 12, 2020.
  1. Aug 12, 2020 at 6:30 AM
    BigSwole
    BigSwole [OP] New Member
    Tony
    2014 Tundra limited
    Hi all, just replaced a original blown turn signal bulb with both led amber bulbs. Now the reason I noticed that front bulb burned out was because of turn signals hyper flashing. My questions are what is the most effective way to get back to normal flash cycles? Also does hyper flashing damage our trucks system?
  2. Aug 12, 2020 at 6:33 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    You will need a voltage regulator as the LED voltage is lower than a regular bulb which will give you a hyper blink.
    GODZILLA likes this.
  3. Aug 12, 2020 at 6:35 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  4. Aug 12, 2020 at 7:02 AM
    BigSwole
    Tony
    2014 Tundra limited
    Thanks TRDFerguson,
    To clarify I don't have any error messages just crazy fast flashing.
  5. Aug 12, 2020 at 7:02 AM
    BigSwole
    Tony
    2014 Tundra limited
    I will order these ASAP
  6. Aug 12, 2020 at 7:10 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, these will get rid of the hyperflash. Just tap the positive and ground for the signal portion of the harness. And you'll also want to mount them on metal, as they get pretty toasty.
  7. Aug 12, 2020 at 7:56 AM
    BigSwole
    Tony
    2014 Tundra limited
    Gotcha, appreciate your help
  8. Aug 12, 2020 at 8:06 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
