hyper flash with good oem bulbs
Discussion in 'Electrical' started by hog teacher, Oct 23, 2022.
  1. Oct 23, 2022 at 11:58 AM
    hog teacher
    hog teacher [OP] New Member
    rick
    2017 Limited TRD 4x4
    3" lift 295/70R19
    when activating the left blinker it hyper flashes. both bulbs are good. removed cleaned and reinserted. still hyper flash. No hyper flash when hazard flashed activated. Ideas?
  2. Oct 23, 2022 at 12:04 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    When you say both bulbs are good do you mean front and rear or both fronts?
    1lowlife likes this.
  3. Oct 23, 2022 at 12:20 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    You've got a short somewhere or a bad bulb.
    It's a different circuit that runs the hazards.
    For instance;
    I have front and rear LED bulbs in my turn signals with VLED resistors.
    I had a short in my resistor wiring on one side.
    The turn signal hyperflashed, but it worked fine with the hazards.
    Once I fixed the bad connection, everything worked fine.
    It's possible your electronic flash module is bad, but I'd think that is unlikely.
    You say the bulbs are good, but I'd try new ones.
    It doesn't hurt to have spares.
  4. Oct 23, 2022 at 12:20 PM
    hog teacher
    rick
    3" lift 295/70R19
    Front and rear, right side flashes at normal speed.
  5. Oct 23, 2022 at 12:28 PM
    Musicmasterd12
    Southern Louisiana
    I’d replace both bulbs as hopefully the cheapest and easiest fix. If that doesn’t work, then agreed you probably have a short somewhere in the wiring
  6. Oct 23, 2022 at 12:35 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    ^ yep..
    I think the rear is a 921
    The front is a 3157ck or 7440 turn signal/DLR
    @hog teacher does your 2017 have amber DRLs in the headlights or the white LED strip on the bottom?
    Just curious..
  7. Nov 14, 2022 at 1:54 PM
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2011 Silver Platinum CrewMax
    Try tracing your wires too and make sure nothing has rubbed the coating off down to bare wire or got hot somewhere and allowed a short to come in the picture.
  8. Nov 14, 2022 at 2:04 PM
    Check the bulb sockets for corrosion or rusted out contacts. That is common.
