Hybrid Diff oil change
Discussion in '3rd Gen Tundras (2022+)' started by jctmundra, Apr 14, 2024.
  1. Apr 14, 2024 at 4:15 PM
    jctmundra
    jctmundra [OP] New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Changed the diff oil in my Hybrid a week ago. Drained about 6qt, 6 oz out of it. I read where the hybrid diff is 10.5 ring vs 9.5 for not hybrid. Manual does not state a capacity difference.
    It came out darkish brown, nothing on the magnet. All good. It did take well over 6qt to fill. Vehicle was close to level.
    Anyone know the stated capacity? I used Redline 75w85.
    Here is the tip - pick up one of these pumps on Amazon. 1oz per stroke vs 4-8cc on the typical pumps. I used a old naglene like bottle and drilled hole in top for pump.
    Jettster likes this.
  2. Apr 15, 2024 at 10:10 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Good job changing the fluid Toyota is giving their diffs a large capacity to help handle all that power...lol
  3. Apr 16, 2024 at 7:05 AM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Some of the gear oils like Amsoil come in those Capri sun like squeeze bottles now, which make changing those fluids a breeze as an alternative to pumping it in.
    eddiefromcali likes this.
  4. Apr 16, 2024 at 7:18 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Lil tip...always crack open the fill plug first, then drain it. If for whatever reason the fill plug is seized, you wont be able to fill it up if you drained it first.
  5. Apr 16, 2024 at 8:48 AM
    eddiefromcali
    Eddie
    100% Stock
    happened to my dad when we were doing a Dana 44 swap on my 55 F100. We had to buy a cover with fill plug :) I say it happened to him because I was only 16 or 17 when it happened. lol.
  6. Apr 16, 2024 at 9:23 AM
    eddiefromcali
    Eddie
    100% Stock
    @ryanwgregg Is there a gasket on the diff cover? I've always used yamabond there but curious if toyota used one or not.
  7. Apr 16, 2024 at 9:38 AM
    eddiefromcali
    Eddie
    100% Stock
    Ah, nice! I'm used to GM diffs with 10 or 14 bolts :) Excuse the newbness
    ryanwgregg likes this.
