Hybrid Auto Stop/Start Button? 23’ TRD PRO
Discussion in '3rd Gen Tundras (2022+)' started by VivaCristoRey, Jan 15, 2023.
  1. Jan 15, 2023 at 1:52 AM
    VivaCristoRey
    VivaCristoRey [OP] New Member
    Dom
    2023 TRD PRO - MIDNIGHT
    Does anyone that owns a new 23 TRD PRO have any insight on how to disable the auto stop/start function?
    I have been very intuitive and adaptable with vehicles my whole life, but after all the research I have done, I cannot for the life of me figure out how to turn it off.
    every single model I am seeing out there has the A button with the circle/arrow around it to temporarily disable the function. But in my 23’ it is not in the dash cluster nor in any option that I can find in settings. Did they take the ability to turn it off away??
    it seems crazy to me that I cannot find it. I’m actually hoping someone is going to make me feel stupid after all the reading and searching I did.
    What am I missing?? I will take a pic if the dash too. The button is simply not in my truck.
    thank you!
  2. Jan 15, 2023 at 2:04 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    The TRD Pro is a hybrid right? I think I saw that the hybrids don’t have the disable button.
    Buildn and VivaCristoRey[OP] like this.
  3. Jan 15, 2023 at 2:28 AM
    VivaCristoRey
    Dom
    So it’s that simple. The Hybrids lose the option to disable auto stop all together? Seems crazy especially for the fact that when the truck is on but no RpM’s, the heat won’t pump. Scenario - if I had someone freezing cold and pulled them in from the elements, I can’t even over ride my truck to get it to pump heat…?
  4. Jan 15, 2023 at 2:28 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I don't believe it's an option on the hybrids. However, if you did have the option it would be in the button cluster to the lower left of the steering wheel... (middle of the top row in this pic) w/ 'A' circled and the word 'OFF' under the circled A
  5. Jan 15, 2023 at 2:35 AM
    VivaCristoRey
    Dom
    I looked at that cluster 100 times feeling like it was going to just pop up and that I missed it. Haha it’s not there…Thank you!
  6. Jan 15, 2023 at 2:46 AM
    Tripleconpanna
    Your welcome... Sorry, that your new rig is without that option; as others have already said, it must have something to do w/the hybrid platform.
    I try to be open minded with the nuances of new technology, but at the same time I find myself gravitating back to more simpler times and technology especially as it pertains to vehicles.
    FISHN43 likes this.
  7. Jan 15, 2023 at 6:17 AM
    Perpendicular
    Perpendicular New Member
    Paul
    Austin, TX
    2023 Capstone
    The Hybrids are designed to run when needed and off when not. If you set the heater to be hot and it isn't, the engine will turn on. If the water in the system is hot and the engine is not required, it can shut off and will still heat up the cabin. Also, as a second note, with the electric motor, you can punch it at take off and the electric motor will get you moving while the engine spins up. Instant power like a motor that is always on without having to be on. A lot of engineering in the design. We bought the hybrid after doing the research and am quite happy with it as well as what it was designed for.
    gnc1017, DesmoDoe and Leif84 like this.
  8. Jan 15, 2023 at 7:17 AM
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    If you do not want your truck (Hybrids that is) to turn off at a stop sign/red light or for any matter, switch your truck in "Tow" mode or manual mode, it'll stay on regardless of what you do.
    But like others have mentioned above, the hybrid system is very well engineered and it's not causing the truck any harm, and IIRC, there are not alternators in the hybrids either!
    DesmoDoe and bballjames like this.
  9. Jan 15, 2023 at 8:14 AM
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    This. If you don't want it to turn off use the tow mode or manual. I think Sport mode also keeps the engine on all the time. But the hybrids do not operate with the standard start/stop feature of the regular gas version. It is very different in that your engine might shut off at low speed but you keep driving. Or even on the freeway for that matter if the engine load is very low. The gas version simply turns off the engine when at a complete stop and then starts again when you let off the break to start to move again. The hybrid also kind of functions that way, but there is way more to it.
    jproy12[QUOTED] likes this.
  10. Jan 15, 2023 at 10:27 AM
    VivaCristoRey
    Dom
    I agree with most of you said and I am also VERY happy with just about every aspect of this new design and technical aspects. But I am experiencing it blowing straight cold air as soon as it flips to electric. That’s been my biggest reason for wanting to keep it on is wanting to know that if after hunting or any other type of outdoor adventure I could easily and quickly heat someone up if needed. I guess I’ll try to put it in tow mode and see if stays on while in park?
    Tripleconpanna likes this.
  11. Jan 15, 2023 at 10:38 AM
    VivaCristoRey
    Dom
    I think it could be a very useful tool having the ability to disable the hybrid for a few reasons. Thanks for everyone’s input. It’s awesome to have people passionate about helping others.
  12. Jan 15, 2023 at 10:41 AM
    VivaCristoRey
    Dom
    So far the first test keeping it in tow/haul whiled parked has kept it on! I will continue to test and let you guys know.
    bballjames and Tripleconpanna like this.
  13. Jan 15, 2023 at 7:13 PM
    xc_tc
    xc_tc New Member
    This doesn’t make sense because the heater and the AC are not powered by the engine, they’re electric. So there’s another issue there.
  14. Jan 16, 2023 at 9:11 PM
    VivaCristoRey
    Dom
    interesting. I’m going to run some more testing and then may get it checked out. Doesn’t seem like it’s kicking heat when it pushes to hybrid.
  15. Jan 17, 2023 at 6:13 AM
    jlocust
    jlocust New Member
    Portland, OR
    2023 Lunar Rock TRD Offroad
    I thought that too, but it turned out to not be the case.
    bballjames[QUOTED] likes this.
  16. Jan 17, 2023 at 7:19 AM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    I've got a hybrid and likely live north of you, so I know the need for heat. I've also had a traditional gas vehicle with auto stop/start that stopped heating/cooling HVAC when the engine shut off (it's annoying). My truck doesn't do this, it does not start blowing cold when the engine shuts off. I know that running in Eco mode changes some HVAC settings but I'm not sure which exactly as I haven't put it in Eco. I don't know if you are ever in Eco or if that could be the cause, but worth checking. If you're not in Eco mode and it's blowing cold air as soon as the engine shuts down with no other changes to the temperature settings, I think you've got some sort of issue as well.
  17. Jan 17, 2023 at 12:06 PM
    Paddockdrive
    Paddockdrive New Member
    2022 Limited TRD Off-Road
    3” TRD Lift, 285/65/20 BF KO2
    He probably does but I have to say compared to the non-hybrid I really never notice my hybrid auto off. It’s almost seamless.
  18. Jan 17, 2023 at 12:29 PM
    bballjames
    Inland PNW
    Ya I totally agree with you. I have to really pay attention to know if the engine is on/off
  19. Jan 17, 2023 at 2:25 PM
    chastings1954
    chastings1954 New Member
    charles
    capstone
    I had a trip pulling a light trailer and used the tow mode. No shut-off at stops. Easy
    VivaCristoRey[OP] likes this.
  20. Jan 17, 2023 at 4:22 PM
    AGTAB
    AGTAB New Member
    Curtis
    Canada
    2022 Tundra limited offroad
    I’m in Canada and have a hybrid. I had to park the truck outside in -20c for a few days. And before I went to pick it up, I cycled the remote start 3x. Showed up to hop in the truck and interior is ice cold, no snow melted off the windshield, but truck was on, engine not running though. I had it left in eco mode, not sure if that was the problem
    anyone else run into that issue?
  21. Jan 17, 2023 at 10:01 PM
    VivaCristoRey
    Dom
    That’s awesome info thank you! That give me the confidence to start narrowing down if there is an issue with it communicating the proper temp inside. It’s a small issue but in extremes where I would have to get someone warmed up I want it to work right. More testing to do!
    DesmoDoe[QUOTED] likes this.
  22. Jan 17, 2023 at 10:03 PM
    VivaCristoRey
    Dom
    you’d think that would allow access to cold and hot temp remote start settings.
    AGTAB[QUOTED] likes this.
  23. Jan 18, 2023 at 6:06 AM
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    Picked up mine two days ago and still learning about the hybrid system ! But I’ll definitely pay more attention when I shut off truck. Never leave it on eco it’s cold as f@ck here too
