HVAC question
Discussion in '1st Gen Tundras (2000-2006)' started by Rolodetective, Oct 16, 2016.
  1. Oct 16, 2016 at 5:46 AM
    Rolodetective
    Rolodetective [OP] Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    I think I've developed some sort of issue with my HVAC system.
    The truck is a 2004 with 95k miles, and is usually only driven weekends. (I've put about 12k miles on it since buying it almost 5 years ago.)
    The HVAC system makes, what I could best describe as, a sort of wheezing sound every 10 seconds or so when the system is on. Wheezing or groaning, then stops, then about 10 seconds later I hear it again. The best picture I can paint is this, imagine a person sleeping and they stop breathing for several seconds then they kind gasp for air. It's not incredibly loud but annoying and a little disconcerting. Sounds the truck interior is breathing.
    It does it on all settings, and it just started doing this in the last week or two.
    Anyone have any ideas?
  2. Oct 16, 2016 at 5:57 AM
    Do the first gen tundra trucks have a cabin air filter?
  3. Oct 16, 2016 at 12:52 PM
    Rolodetective
    2004 Black AC TRD
    They do not
  4. Oct 16, 2016 at 1:16 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Your truck has sleep apnea?
    AaronK, Law323 and joonbug like this.
  5. Oct 16, 2016 at 1:33 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Dammit. Got to it first LOL
  6. Oct 16, 2016 at 2:27 PM
    Mike Tread lightly.
    south carolina
    Blower motor bearing maybe....
    Or squirrel cage hitting something or caught something in it making the noise.
    driverdog likes this.
  7. Oct 16, 2016 at 2:34 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    Vacuum leak maybe?.
  8. Oct 16, 2016 at 2:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You can recommend breathe-right strips. I'll give you full credit.
    Law323[QUOTED] likes this.
  9. Oct 16, 2016 at 2:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are you able to nose around to try to determine more precisely the origin of the sound. Fan motor, A/C compressor, the like.
  10. Oct 22, 2016 at 5:09 AM
    Rolodetective
    2004 Black AC TRD
    I will.....I was just hoping I didn't have to do exploratory surgery. I was betting someone has had this same issue....but I lost that bet. Thanks for the thoughts gents, I'll post back if I determine what it is.
  11. Jul 8, 2017 at 6:01 AM
    Rolodetective
    2004 Black AC TRD
    I promised I'd post back if I found the problem and I have.....what I also learned, based on the dates of my posts....is that I do not drive my truck enough. WOW.
    Anyway....it was an A/C issue. If you open the hood, you will see a coupling in front of the radiator on the far right side. There is a seal there...these seals tend to deteriorate causing a freon leak. The system is meant to be a pressure system, thus as the pressure was trying to build, the seal would leak causing the pressure to bleed back down. That pressure bleed was the "exhaling" I was hearing.
    So, $100 later and all is good. (seal was like 2 bucks, dye for test was a few bucks, freon was like $37 bucks....rest was labor.)
    Hope this helps someone.
