HVAC problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Prestoman13, Apr 30, 2023.
  1. Apr 30, 2023 at 6:03 AM
    Prestoman13
    Prestoman13 [OP] New Member
    Preston
    2008 crewmax SR5
    So I finally am in the tundra nation and bought a 2012 tundra crew limited with TRD supercharger. I had a nice test on a 850 mile trip back from from purchase. When I test drove the truck, everything seemed to be fine. All the modes work, all vent changes happen. On the drive home the ac was blowing cold, but my leg started to get warm from the console. Well it turned into really hot and was uncomfortable and my drink was warm. The rear vents are blowing hot air. My first thought was Ac actuator motor, but all the changes happen when going through different vent positions. Is this still the problem or would it be something else?
  2. May 1, 2023 at 4:31 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Check the mag/clutch relay, they go bad frequently in Toyotas
    Prestoman13[OP] likes this.
  3. May 3, 2023 at 4:57 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Whats the Mag/Clutch Relay? you mean the AC Clutch?
  4. May 3, 2023 at 5:10 AM
    Danny3737
    It’s a relay in the fuse box under the hood. I’ve had to replace it in every Toyota I’ve owned.
    baraynavab[QUOTED] likes this.
  5. Jun 4, 2023 at 5:47 PM
    Prestoman13
    Preston
    2008 crewmax SR5
    Will check tomorrow. Thank you. I didn’t get notified of a reply.
