Hutcheson’s frame restoration
Discussion in '1st Gen Tundras (2000-2006)' started by Hutcheson, Jun 24, 2024.
  1. Jun 24, 2024 at 11:28 PM
    Hutcheson
    Hutcheson [OP] New Member
    Caleb
    2004 DC Limited
    Figured I’d start a thread documenting my mid frame restoration. Plugging away at it when I can find some spare time.
    I’ll try my best to go over everything I’ve done but it’ll most likely be a picture heavy thread.
    Trucks a 2000 Tundra 4.7L V8 AC with 260000km
    I went with the SafeTCap by Autorust. Part #ART-242X-S
    Here’s what I’m working with. Starting with the drivers side.
    IMG_9255.jpgIMG_9269.jpg IMG_9321.jpgIMG_9360.jpgIMG_9362.jpgIMG_9363.jpgIMG_9366.jpg IMG_9367.jpg IMG_9373.jpg IMG_9323.jpg IMG_9369.jpg
  2. Jun 24, 2024 at 11:30 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Thats as far as I’ve gotten so far, pulling the stiffener out has unveiled rust thicker than my frame and instead of 1 hole I now have 2. Should have the frame prepped for welding by tomorrow with a template made up of the new stiffener.
    JasonC. and Jack McCarthy like this.
  3. Jun 25, 2024 at 3:07 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    Great work. Good pics. Looking forward to watching this process, thanks for sharing:thumbsup:. Smart move with the extinguisher!
    Curious, so I looked those parts up, not so bad considering what you are saving.
    https://www.autorust.com/product/mid-frame-section-w-spring-mount-art-242x-s-set/
    Hutcheson[QUOTED][OP] likes this.
  4. Jun 25, 2024 at 4:45 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Subscribed! Nice work so far. Looking forward to seeing your progress.
    Hutcheson[OP] likes this.
  5. Jun 25, 2024 at 6:43 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Nice! I look forward to watching this thread and seeing how it turns out.
  6. Jun 25, 2024 at 7:45 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Spent a few hours after work today cleaning up the area being welded, finished removing the last of the rivets, needle scaled the inside of the frame and got a template made for the new stiffener. I’ll be dropping that off at the shop tomorrow and hopefully get my new spring mount installed soon.
  7. Jun 25, 2024 at 7:48 PM
    Hutcheson
    Caleb
    2004 DC Limited
    The new spring mounts appear to be a bit wider internally, not sure if that’ll pose a problem or if I’ll just need wider bushings when I get my new leafs. The old mounts needed some prybar action whereas these ones fit freely.
  8. Jun 25, 2024 at 9:39 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    My hats off to you. That’s a lot of work and it appears you’re taking the time to do it correctly.
    BroHon and Hutcheson[OP] like this.
  9. Jun 25, 2024 at 10:11 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Appreciate it, makes me feel good knowing I’m doing it to the best of my abilities. Looking forward to getting it back on the road.
  10. Jun 26, 2024 at 3:31 AM
    tvpierce
    Maine
    Looks great! What's the plan to treat the bare metal between layers?
    des2mtn likes this.
  11. Jun 26, 2024 at 5:17 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I'm following this with great interest! I'm also curious about the application of the autorust part. It seems that it is intended to replace the stiffener on the outside of the frame, obviating the need for an internal stiffener. Why do you feel the need to do both?
  12. Jun 26, 2024 at 5:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ain't it obvious? Every failure is a chance to upgrade!
    BEEF! :benchpress:
  13. Jun 26, 2024 at 5:21 AM
    w666
    Maryland
    Or in other words..."if one is good then two must be better"!
    Tundra2[QUOTED], BroHon and bmf4069 like this.
  14. Jun 26, 2024 at 5:46 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Great work man! I see you are a man of culture with that beautiful cardboard template.
    I think @Tundra2 said it somewhere else, but that spring mount will likely deflect in fine when tightened. You might try sending auto rust/safetcap an email with those images. After all they probably know their product better than any of us.
  15. Jun 26, 2024 at 5:51 AM
    w666
    Maryland
    After consulting my advisor google I'm learning that that weld through primer or epoxy primer may be suitable for the inside surfaces. Plusses and minuses for both techniques. Also there's another process for which I am not familiar called "cold galvanizing", a spray on coating that functions more or less the same. I'm skeptical, plus welding through zinc is not my idea of a good time.
    Toyota appears to have relied on only paint, however, which is why we all have this problem to some degree or another...
    bfunke, Hutcheson[OP] and BroHon like this.
  16. Jun 26, 2024 at 6:00 AM
    JakeJake
    2000 Tundra AC 4X4
    A good weld thru primer will contain zinc, so heads up on that.
    The key here is to place a continuous weld between layers. Rust needs a steady supply of oxygen for the reaction to continue.
    If it's a sealed chamber it will last forever regardless of what it gets treated with beforehand.
  17. Jun 26, 2024 at 7:42 AM
    Hutcheson
    Caleb
    2004 DC Limited
    Couldn't have said it any better myself!
  18. Jun 26, 2024 at 10:30 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Boss man.... It says:
    >The ART-242X also comes with an inner frame support plate to be used where necessary.
    Did you not get one?
  19. Jun 26, 2024 at 4:05 PM
    Hutcheson
    Caleb
    2004 DC Limited
    @JakeJake touched up a bit on it further down, i
    You betcha I did, they came with 6 of them but rather than just slapping those on where I see fit I opted to just make an entirely new stiffener instead.
  20. Jun 26, 2024 at 4:24 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Excellent work!
  21. Jun 26, 2024 at 4:29 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Cheers! I had no intentions of doing this when I bought the truck, but then again I didn’t look that hard enough for rust ‍♂️ Thankfully the rest of the frame is in great shape..
  22. Jun 27, 2024 at 5:02 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Baby steps the last few days, more or less just preparing the metal for when the welder comes out. Should be in the next week and a half. Wish it was something I was capable of doing as I’d like to drive my truck lol.
    Picked up my new frame stiffener today, dry fit it and it goes to my buddy tomorrow to be tack welded and then back to me for a second dry fit.
    3/16” thick
  23. Jun 27, 2024 at 5:11 PM
    shifty` I'm having daydreams about night things
    That OEM stiffener looks pretty good.
  24. Jun 27, 2024 at 5:14 PM
    Hutcheson
    Caleb
    2004 DC Limited
    It’s what was behind it that I didn’t like
  25. Jun 27, 2024 at 5:18 PM
    Is that the framerail, or the stiffener though? I see where the stiffener is looking pretty thin at some of those holes, but the condition of the steel outward looks pretty intact.
  26. Jun 27, 2024 at 5:22 PM
    Hutcheson
    Caleb
    2004 DC Limited
    It’s a little bit of both, more so the frame rail. Left me with 2 good sized holes on the frame rail and a tiny guy on the bottom flange above the spring mount. In hindsight I probably could have left the old stiffener and been okay but seeing as I’ve opened it up I felt the need to beef it up some more.
    shifty`[QUOTED] likes this.
  27. Jun 27, 2024 at 5:26 PM
    If you're gonna be in there, may as well set it up for the next 8-10 years without issues...
  28. Jun 27, 2024 at 5:28 PM
    Hutcheson
    Caleb
    2004 DC Limited
    That’s the plan anyways..
  29. Jun 28, 2024 at 8:44 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Got the stiffener all welded up, holes picked up and drilled out. If I was being picked I could have made my cardboard template a little bigger lol. Tightening the bolts should close the gaps. All in all I’m quite happy with the fitment. I’ll get the area painted tomorrow, stiffener put in, cross brace in and hopefully throw the exhaust back in.
    des2mtn, bmf4069, Blindsider and 6 others like this.
  30. Jun 29, 2024 at 4:03 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Nice work!
