Hurricane dorian/tundra/gas removal
Discussion in 'General Tundra Discussion' started by Freonjohn, Sep 1, 2019.
  1. Sep 1, 2019 at 5:04 PM
    Freonjohn
    Freonjohn [OP] New Member
    So, I live in coastal Georgia and with hurricane Dorian bearing down I’m prepping for it
    Last hurricane(Matthew)
    We lost power and water for 6 days. Learned a lot about prepping on that ordeal
    So the tundra fuel tank is topped off and I have 25 gallons gas on hand for generator.
    Suppose I wanted to use gas from tundra for generator?
    Any ways to safety remove?
    Would be cool to have that much extra fuel reserve for generator
  2. Sep 1, 2019 at 5:05 PM
    Could get a siphon pump I suppose
  3. Sep 1, 2019 at 5:08 PM
    Blueknights75
    Ron
    Clayton, NC
    This^^
    Pinay likes this.
  4. Sep 1, 2019 at 5:09 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    ^^^^ DITTO
    - no drain in fuel cell
    - siphon be ur best bet
  5. Sep 1, 2019 at 5:09 PM
    Keep in mind, OP- you may need that fuel if you need to travel in your vehicle to avoid a certain area, move around debris, safer locations, etc.
    Migraine and Midnite72 like this.
  6. Sep 1, 2019 at 5:13 PM
    Freonjohn
    Thought there would be screen to prevent siphoning hose from reaching tank?
    OR18TRD and Black Wolf like this.
  7. Sep 1, 2019 at 5:14 PM
    P-Factor
    P-Factor New Member
    Yup. Siphoning hose can be your best friend in times of need. In Georgia we call a siphon hose a "Georgia credit card". ;)
    NewImprovedRon likes this.
  8. Sep 1, 2019 at 5:17 PM
    koditten
    Kirk
    Midland of the Mitten
    Nope.
    There is a screen in the fill tube of all Toyota vehicles. No way to snake a siphon tube to the gas in the tank.
    ColoradoTJ and OR18TRD like this.
  9. Sep 1, 2019 at 5:19 PM
    Midnite72
    Bill
    Northern MD
    18 SR 5.7 4x4
    Always a Spoiler !!!
    Darnetttt !!
    koditten[QUOTED] likes this.
  10. Sep 1, 2019 at 5:25 PM
    koditten
    Kirk
    With that said, if a tree falls on your tundra, you can punch a hole in the tank with a center punch. Drain the tank into a low gas can. Keep a golf tee handy to plug the hole as you change gas cans...
    Trucks not gonna do you much good with a tree across the cab. Might as well use the gas in the thing.
    Ely010606, ColoradoTJ and Black Wolf like this.
  11. Sep 1, 2019 at 5:28 PM
    There is.
  12. Sep 1, 2019 at 5:29 PM
    Woody40
    Woody40 New Member
    Panama City Florida
    2017 Tundra
    3/1 lift, BFG KO2's, Westin black drop steps, 2019 TRD PRO Grille, Black out bumper caps, Black out emblems, Winjet taillights
    Hopefully you wont have to worry about any of that. I live in Panama City, and rode out Hurricane Michael last year. Will never do that again if I can help it.
  13. Sep 1, 2019 at 5:30 PM
    I would have gassed up and headed west for a few days. :thumbsup:
    NewImprovedRon and jewsNbrews like this.
  14. Sep 1, 2019 at 5:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I pump fuel out of tanks by disconnecting the fuel hose and turning the fuel pump on. (You need a scan tool for this though)
  15. Sep 1, 2019 at 5:37 PM
    P-Factor
    P-Factor New Member
    The filler neck screen will be laying in the bottom of tank if I need the gas.
    Another option is to energize the fuel pump at the fuse block, connect a hose directly to the fuel rail and let the pump do the work for you.
    Pudge, OR18TRD and Black Wolf like this.
  16. Sep 1, 2019 at 5:51 PM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    I would check in at the biggest sturdiest hotel building in town with an indoor pool.
    koditten likes this.
  17. Sep 1, 2019 at 6:09 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    A generator will run for quite awhile on 25 gallons. I'd keep my Tundra prepped for a mad dash if needed. Don't ride out this storm unless it's absolutely necessary. It's an absolute beast. Best of luck. We're with you. :thumbsup:
    Black Wolf likes this.
  18. Sep 1, 2019 at 6:11 PM
    Freonjohn
    Already got a hotel room booked out of town in case conditions get too bad
    Just thinking about senerios when returning
    OR18TRD, Black Wolf and jewsNbrews like this.
  19. Sep 1, 2019 at 7:09 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Wonder why I was able to siphon gas out of my Tacoma then.
  20. Sep 1, 2019 at 7:25 PM
    koditten
    Kirk
    What year?
  21. Sep 2, 2019 at 12:40 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    99
  22. Sep 2, 2019 at 2:02 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    How Are WE sure this isnt your neighbors Tundra? Do you even own one?o_O
    T-Rex266 and OR18TRD like this.
