Huntark's 05 4X4 Limited Build
Discussion in '1st Gen Builds (2000-2006)' started by huntark03, Jan 20, 2014.
  1. Jan 20, 2014 at 5:43 AM
    huntark03
    huntark03 [OP] New Member
    Maumelle, AR
    2005 Toyota Tundra Limited 4X4
    Front Bilstein 5100's w/ OME 885 coils Rear Bilstien 5100's w/ ToyTec 1.5" AAL Light Racing UCA's Drop in AFE Pro Dry Air Filter
    After owning several Toyota trucks, I knew I didn't want anything different. I bought an 05 Limited 4x4 in December 2013 and immediately started changing things. It started out bone stock.
    I made enough on my 2003 Tundra to start buying parts. I took Tacoma TSS wheels and wrapped them in the 265 70 17 Toyo Open Country AT2s that came on the truck, coupled with the Spidertraxx wheel spacers I already had. I then installed front and rear Bilstein 5100s set on zero lift with OME 885s and Toytec 1.5 " AALs. I ordered new rebuilt CV axles from CVJ Axles and had them put Porche 930 inner boots on them. To be continued...
    Rheywood456 likes this.
  2. Jan 20, 2014 at 6:53 AM
    Clean looking truck!
    huntark03[OP] likes this.
  3. Jan 20, 2014 at 12:42 PM
    huntark03
    Maumelle, AR
    Thanks Sean! I will take some more pictures and update this more later!
  4. Jan 22, 2014 at 8:09 AM
    Halsam00
    Halsam00 New Member
    2000 Toyota Tundra AC 4x4 Lmtd
    I love those wheels, if I put a set of those on a stock 2000 AC 4x4 will they rub?
  5. Jan 22, 2014 at 8:59 AM
    huntark03
    Maumelle, AR
    Thanks! I believe they stick out slightly farther than stock tundra wheels. If they rub at all it will be on the mud flap, and I believe it would take 265 70 17s to start rubbing.
  6. Jan 22, 2014 at 9:08 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Man I would never get rid of that truck! Pristine!!!
  7. Jan 23, 2014 at 9:58 AM
    huntark03
    Maumelle, AR
    Thanks TruckyTruck. Once I get done with front end work, I will be mucho happier!
    TruckyTruck likes this.
  8. Jan 11, 2019 at 2:05 PM
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Nice!
    How long did your CVs from CVJ last?
