Humming/vibration intermediate
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra_power, Nov 20, 2020.
  1. Nov 20, 2020 at 7:36 AM
    Tundra_power
    Tundra_power [OP] New Member
    Nick
    Hello I have 2008 tundra and I just replace my coilovers and went with stock trd 4600 yellow and blue ones from a 2019. Just my luck I put the passenger coilover on the driver side and the driver coilover on the passenger side not knowing theirs a difference between the two. So than I added 2 shims on the driver side to make it even. Just got new tires toyo at3 also and now I have a vibration/ humming going over 70mph. It comes and go every 2 seconds. I can feel it on the floor board very annoyed. Everything is tight. can it be a bad ball joint causing the vibration. It started after I put the new coilovers on.IMG_20201118_202941264.jpg
  2. Nov 20, 2020 at 7:41 AM
    Tundra_power
    Nick
    So I just make sure it wasn't a carrier bearing problem so I went under the truck and I can move the driveshaft within the bushing it has some play. When I tried to turn the driveshaft theirs no play what so ever just within the bushing. It's weird i never had this vibration issue until I lift the truck around 1in in the front. The driveshaft is not completely straight it looks like it's sinking in near the carrier bearing.IMG_20201120_001009923.jpg IMG_20201120_001154126.jpg
  3. Nov 21, 2020 at 5:09 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    @Tundra_power maybe it’s the front diff bearing on drivers side. Give the cv axle a wiggle and compare to the passenger side.
    Your every two seconds description sounds like how I would have described my diff bearing gone bad and could feel in gas pedal.
  4. Nov 21, 2020 at 5:44 PM
    Tundra_power
    Nick
    I lifted the truck I put my hands on the 9 clock and 3 clock position on the tire and it did wiggle alot on both sides but more on the driver side put I can hear the steering wheel shakes inside the cab while I did it. I put my hands on the 12 and 6 position and no movement at all so this leads me to believe it could be the tie rods? Or is this normal..
  5. Nov 21, 2020 at 7:20 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    @Tundra_power that is the test for tie rods but I believe someone else needs to hold the opposite wheel still. What you described sounds normal though.
    I was talking about where the CV axle enters the front differential in my previous post. Of course I am assuming you have 4wd.
  6. Nov 21, 2020 at 7:25 PM
    Tundra_power
    Nick
    No I am 2wd. What's weird is when I turn to the right at full lock my driver side goes down alot and when I do that I can feel poping in the steering wheel. Has to be either ball joint or tie rod.. but theirs no play on the 12 and 6 clock position of the tire...
  7. Nov 21, 2020 at 7:28 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Oh, I’m sorry. I’m not of much use then. Sounds like your bearings are tight so not sure what else would cause that.
  8. Nov 21, 2020 at 7:37 PM
    Tundra_power
    Nick
    I mean it feels more of a vibration than anything. I'm not to sure if a tie rod or a ball joint can cause pulsing vibration.
  9. Nov 21, 2020 at 7:38 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Maybe double check the rear bearings.
  10. Nov 21, 2020 at 7:42 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Also can try rotating tires and see if it goes away.
  11. Nov 21, 2020 at 7:43 PM
    Tundra_power
    Nick
    All brand new tires and all of them rebalance..
