Humming Noise at 45MPH '06 Sequoia
Discussion in '1st Gen Tundras (2000-2006)' started by 70 FJ40, Nov 1, 2023.
  1. Nov 1, 2023 at 5:05 PM
    70 FJ40
    70 FJ40 [OP] New Member
    Max
    '16 Tundra SR5 TRD 4X4 Double Cab
    My sister has a Sequoia that is having an issue they can't figure out. It has a loud humming at 45 MPH. If they speed up or slow down the noise goes away. The truck has 145k miles. I think they are 2nd owners. She said slight vibration with noise as well. A mechanic friend suggested may a wheel bearing going bad but how would you tell which one?
    I told her I'd see if someone else on the forum had similar issue.
    Any ideas or ways to check wheel bearings?
    Thanks
  2. Nov 1, 2023 at 5:46 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    New tires? My BFG KO2s had some humming at first…
  3. Nov 1, 2023 at 6:18 PM
    shifty` In South Dakota Trouble ain't hard to find
    Skip to 1m26s if it doesn't auto-jump there:
  4. Nov 1, 2023 at 7:41 PM
    70 FJ40
    Max
    Hey. Thanks. That's a great video. I'll send it over to my brother-in-law.
