How to wire used camper shell brake light?
Discussion in 'Wheels & Tires' started by Nick244, Apr 18, 2023.
  1. Apr 18, 2023 at 12:37 PM
    Nick244
    Nick244 [OP] 05’ RCLB 4.7 4WD with 27k miles
    Nick
    California
    Can anyone direct me to a wire harness that would be compatible for an A.R.E Aluminum camper onto my 1st gen Tundra for the brake light, or a link to someone already doing this project?
    I figure it won't be too tough to run a wire through the car, but am wondering what is a compatible part and how to connect to battery.
  2. Apr 18, 2023 at 2:02 PM
    @Puppypunter maybe?
  3. Apr 18, 2023 at 3:13 PM
    biebs96
    PA
    When I had a cap on a previous tundra I used a 4 flat trailer plug inside the bed so the wires could be disconnected easily.
    Used the four wires as two pairs.
    One pair for a ground, and tapped off the hot behind the driver brake light.
    The other pair for a ground and direct 12v feed from the battery for a dome light.
    hope this helps.
  4. Apr 18, 2023 at 3:59 PM
    rock01
    rock01 New Member
    Rich
    2006 Tundra SR2 2wd
    front hitch, timbrens, camper shell
    Since I only need that light when I am not towing, I wired it to a 4 way trailer plug and plug it into the trailer plug.
  5. Apr 28, 2023 at 3:28 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    ARE sells a universal harness to connect the shell to your battery for dome light/power port purposes. Then you just tap into tail light wiring for the third brake light. Check with your local ARE dealer, they probably have one on hand.
