How to weld Tundra body safely?
Discussion in '2nd Gen Tundras (2007-2013)' started by liker777, Sep 6, 2020.
  1. Sep 6, 2020 at 2:45 AM
    liker777
    liker777 [OP] New Member
    Oleg
    2007 lmtd ext 4x4 5.7
    Iron bumpers
    Hi there
    Could you please help a novice with the following:
    I have 2007 Tundra limited. Frame mounts for bumper are damaged. So I would like to weld them a bit.
    I have never did welding on any car before. I heard I need to disconnect the battery. Should I do something else? So not to damage car electronics etc...
    Sorry having problems with uploading the image. So I just post a link to the mount photo here: https://ibb.co/MBMtzbY
    Mountun Goat likes this.
  2. Sep 6, 2020 at 8:40 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    If the mount is removeable I would take it off the truck, weld and then clean and paint or powder coat. If it is part of the hitch system there are like 10 bolts to remove.
    liker777[OP] likes this.
  3. Sep 6, 2020 at 8:43 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    The battery disconnect is about it. I steady weld on my truck with battery connected even since I’m lazy. Go for it.
    smslavin, snivilous and Geo4x4 like this.
  4. Sep 6, 2020 at 10:19 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Disconnecting the battery sounds like a good plan.
    Other than that, the primary rule when welding on machinery is to not place your ground cable such that the current path will run through any bearings. For example, don't attach your ground to the rear axle housing for welding on the frame. Place the ground cable near where you are actually welding.
  5. Sep 6, 2020 at 10:46 AM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Definitely disconnect battery stand back look at what your going to weld and imagine weld spatter so protect what you don’t want burnt or melted
    Geo4x4 likes this.
  6. Sep 6, 2020 at 1:01 PM
    liker777
    Oleg
    Iron bumpers
    Thanks for the reply! Unfortunately that mount is just a small extension of the frame, some time ago this mount per se was welded to the frame )
  7. Sep 6, 2020 at 1:01 PM
    liker777
    Oleg
    Iron bumpers
    Thanks! Will do
    Mountun Goat[QUOTED] likes this.
  8. Sep 6, 2020 at 1:02 PM
    liker777
    Oleg
    Iron bumpers
    Thank you! I will put the ground right on the same mount that is to be welded
  9. Sep 6, 2020 at 1:03 PM
    liker777
    Oleg
    Iron bumpers
    I got it. I will cover the hood with something to stop sparks
  10. Sep 6, 2020 at 4:02 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Are you just repairing the crack from the hole to the edge ? Thats an easy repair and a good one to learn on. Besides what has been recommended, grind it out, clamp it so its flush and tack it, move your clamp and tack again and then weld it out. Make your first tack in the hole. When you're done grind the hole tack with a die grinder and your done.
  11. Sep 6, 2020 at 4:14 PM
    liker777
    Oleg
    Iron bumpers
    Unfortunately, the picture does not show the whole problem... And it is worse..
    Please see crack from behind of the mount:
    https://ibb.co/tmwGWnJ
  12. Sep 7, 2020 at 2:18 AM
    liker777
    Oleg
    Iron bumpers
    An update - just found it in the repair manual:
    When using electric welding anywhere on the vehicle, disconnect the center airbag sensor connectors. These connectors contain shorting springs. This feature reduces the possibility of the airbag deploying due to currents entering the squib wiring.
    rockmup likes this.
  13. Sep 7, 2020 at 6:50 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    :eek: :bananadead: :censored: :canada: :boink: :cheers:
    Mountun Goat[QUOTED] and Geo4x4 like this.
  14. Sep 7, 2020 at 8:53 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :cheers::headbang:
