How to turn a 5 min job into a 3 hour job ...
Discussion in 'Lighting' started by rockjockey, Oct 29, 2016.
  1. Oct 29, 2016 at 6:52 PM
    rockjockey
    rockjockey [OP] Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    An idiot's tale:
    - decide to change out roof console map light bulbs with LEDs in my 2016 CM
    - pop off plastic lens cover - no problem
    - attempt to remove bulb with fingers - burn fingers and say a bad word
    - attempt to remove bulb with needle-nosed pliers - manage to blow the fuse controlling lights
    - check manuals - confusing as to which fuse controls interior lights
    - assume (incorrectly) that interior lights = interior fuse box
    - attempt to access interior fuse box while lying upside down in wheel well & wearing bifocals
    - say two bad words
    - check all 7.5 amp mini fuses and drop the last one behind the kick panel while replacing it
    - say three bad words
    - remove kick panel & recover fuse & replace kick panel
    - swallow pride and log in to Tundras.com forum
    - get almost immediate answer to fuse location question (thanks again, NinjaTurtle!)
    - open hood and locate correct fuse
    - run to auto parts store & discover they don't sell packages of multiple 7.5 amp mini fuses
    - buy pkg of assorted mini fuses for $5 to get one 7.5 amp mini fuse
    - mutter to self to avoid saying bad words out loud in store
    - return home and attempt to replace mini fuse under hood - drop fuse under battery tray
    - say four bad words
    - go to three more auto parts stores in order to find another 7.5 amp mini fuse
    - return home and manage to replace fuse and install LED bulb
    - celebrate too early
    - pop plastic lens off other side thinking this will be a breeze now that I'm an expert
    - remove old bulb successfully
    - attempt to install new bulb - in doing so manage to loosen metal contact in console housing
    - discover there is no way to fix contacts without removing roof console
    - curse a blue streak using all the words I learned from three generations of farmers
    - return to Tundras.com forum and ask if anyone has link to video showing removal of said console? ....
    On the plus side, not once did I have to stop and look for my 10mm socket.
  2. Oct 29, 2016 at 6:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lmao!!
    Major likes this.
  3. Oct 29, 2016 at 7:03 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    :rofl:That's some funny shit!
  4. Oct 29, 2016 at 7:19 PM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Feel your pain
  5. Oct 29, 2016 at 7:21 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    LOL yep. Took me an hour and a half to get mine in.
    Murphy's Law takes precedence over smooth sailing every damn time!!
    GODZILLA, 4x4_Angel, geno0506 and 4 others like this.
  6. Oct 29, 2016 at 7:31 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That is really really well written! Funny stuff. I feel your pain, and this particular bullet I saw coming and dodged. I wanted to do this mod but after reading 30 plus posts about it going south (some from fuses, some from broken light connector parts, some from bad lights from manufacturers, etc) I decided that the factory lighting was okay
  7. Oct 29, 2016 at 7:49 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Yup, been there... Done that. :frusty:
    kenomouth64, geno0506 and driverdog like this.
  8. Oct 29, 2016 at 7:56 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    What pisses me off is that these trucks should come with premium bulbs already! I dont wanna dick with it!
  9. Oct 29, 2016 at 8:01 PM
    Well I just spit coffee all over the place.
    Post of the year entry? I think so....
  10. Oct 29, 2016 at 8:07 PM
    rockjockey
    Spring, TX
    Glad to know I'm not the only one who had trouble with this. I hereby promote myself from idiot to doofus!
  11. Oct 29, 2016 at 8:19 PM
    I would call your little problem a learning experience and maybe a good reason to have some bourbon tonight.
    There was a thread on TundraTalk on a guy taking off all his factory emblems. He couldn't get the glue off and it was the funniest thread I have ever read.
  12. Oct 29, 2016 at 8:27 PM
    rockjockey
    Spring, TX
    Oh yeah, I forgot to list the step involving whiskey. That was repeated several times to good effect.
  13. Oct 29, 2016 at 8:51 PM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    Easy way to do it:
    1) Think about doing the LED mod
    2) Read up on other members experiences with doing the LED mod and having many many problems.
    3) Realize my factory lighting is just fine and not to fuk with it.
    Tom Sleight, Big J, Piney and 15 others like this.
  14. Oct 29, 2016 at 8:57 PM
    TheBeast The Beach
    haha my story last week end..going again at it tomorrow since now I got new LEDs..oh and HIDs too...
  15. Oct 29, 2016 at 8:59 PM
    TheBeast The Beach
    @csuviper or @Sean266 removed the console housing. It's in one of their posts with pictures.
  16. Oct 29, 2016 at 9:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  17. Oct 29, 2016 at 9:09 PM
    NinjaTurtle
    NinjaTurtle New Member
    Truckee
    2016 Bronze Limited DC
    Removing the console is easy, just have to pop the card holder trim with some sort of soft pry tool, 2 torx bolts under there, I think T30 or T35. Then 2 more torx in the sunglass holder. I can check the size in the morning if you want.
    That's how it is on my double cab.
    rockjockey[OP] likes this.
  18. Oct 29, 2016 at 9:16 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Hilarious
  19. Oct 30, 2016 at 2:33 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    wisdom knot's on my head from laughing so hard..sounds like almost every job I ever did
    NewImprovedRon likes this.
  20. Oct 30, 2016 at 5:52 AM
    rockjockey
    Spring, TX
    Thanks for all the kind comments and suggestions - will tackle the console today now that I have a better idea how it comes off (as usual, info from this site SO much better than what's in the manual).
  21. Oct 30, 2016 at 6:02 AM
    NJMIke
    NJMIke New Member
    2016 Tundra Double Cab SR5
    Rial cast wheels. Looking for TRD Pro grill with chrome surround
    Damn you had me laughing so hard at this. Changed mine with similar results including the search for 7.5amp fuses at 4 auto stores. Toyota furnishes a few spare fuses in your box but not the 7.5 amp ones.
    Other differences were:
    - much more cussing (dad would have been proud)
    - lots of whiskey (dad would have been jealous)
    - I did get some good advice from Law about being careful about removing map light reflector. I was not careful enough and broke off one of only two ears that holds it in place. Just put it back together without the map light left side reflector. I'll put it back some day with glue?
    - led bulb contact end width is a little wider than std bulb which makes it easy to crush/distort contacts which I did on the 1st one changed
    - used pliers to straighten contacts is how I blew my fuse
    - total frustration with the thin contact wires on led bulbs not making good contact. Finally figured easy solution was to rebend the wires to hit socket contacts better
    I do like the led light though once all has been completed.
  22. Oct 30, 2016 at 7:08 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Just caught your post. I did my weekend morning routine. Got up and took a leak, brushed my teeth, put some coffee on and turned on the computer. Even after my morning leak, I think I still pissed my pants laughing reading your thread John. That's one of the things that makes this forum so GREAT. We can all struggle with our projects on our trucks and still get a laugh out of it. I don't want to wet my pants again, so think I'll stick with the OEM lighting. Good luck finishing up the project.
    GODZILLA and rockjockey[OP] like this.
  23. Oct 30, 2016 at 10:11 AM
    TheBeast The Beach
    btw would it be best to remove fuse during LED install or disconnect battery ? seems like it might be easier to remove fuse the check all LEDs OK (polarity) then put it back instead of keeping connecting/disconnecting battery.
  24. Oct 30, 2016 at 10:11 AM
    TheBeast The Beach
    this post should be a sticky IMO to warn future members. This is very common. my 0.02
    aperezsh, rons23, driverdog and 2 others like this.
  25. Oct 30, 2016 at 10:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think just the fuse is good enough. I don't like disconnecting battery if it's not necessary.
  26. Oct 30, 2016 at 10:14 AM
    TheBeast The Beach
    just wanna make sure I'm not shorting another circuit somewehere else..lol..I just got my VLEDS in...so I'm ready to tackle the project..take #2 !
    Law323 likes this.
  27. Oct 30, 2016 at 10:29 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Exactly!
    15whtrd and DalTee like this.
  28. Oct 30, 2016 at 3:15 PM
    rockjockey
    Spring, TX
    Yeah, Mike, I also thought I could get the reflector out without damaging it (hah!). Hopefully I can get it back in properly when I take the console out to fix the contacts. I'll be doing that this week and will take lots of pic to hopefully help those who attempt this in the future. Also, thanks to csuviper for the link to the pics of the console! Thanks, guys - love this forum!
  29. Oct 30, 2016 at 4:12 PM
    rockjockey
    Spring, TX
    Since I had so much trouble finding 7.5 amp fuses, here are a few links to sites that sell them in multiples ...
    5 pack from Amazon (5 pack for $7.99 + $4.79 S+H)
    https://www.amazon.com/Toyota-Lexus...r=1-15&keywords=7.5+amp+low+profile+mini+fuse
    Del City (order as many as you want, $0.78 ea):
    https://www.delcity.net/catalogdetails?item=87075
    Cloud Electric (order as many as you want, $0.52 ea):
    http://www.cloudelectric.com/product-p/wirth-24157.htm
    Not sure about shipping for the last two sites - didn't want to go through checkout just to get shipping cost.
    If you search for these fuses on the web make sure you specify LOW PROFILE mini fuses, which look like this:
    If you just search for "mini fuse", you'll get these (which you DON'T want):
    GODZILLA, jburson250 and MotoTundra like this.
  30. Oct 30, 2016 at 4:52 PM
    TheBeast The Beach
    finished installing my VLEDS. no issues to report. I made sure to remove fuse during work. Map lights shields were a bitch to put back on.
    I also installed the foot well LED kit while I was at it. very nice feature IMO.
    I got my LEDs from vleds.com
    they have 15% off right now.
    http://www.vleds.com/shop-application/footwell/74/tundra-fwk-bar.html
