How to run reverse camera wire from receiver to camera on tail light?
Discussion in '1st Gen Tundras (2000-2006)' started by Lilsuge40, Jun 1, 2020.
  1. Jun 1, 2020 at 10:52 AM
    Lilsuge40
    Lilsuge40 [OP] New Member
    2006 Tundra SR5 ext cab
    I need help please and asap!! I have a 2006 Toyota Tundra ext cab SR5. I’m trying to install a reverse camera (Kenwood CMOS-230) but don’t know how to run the wire from the receiver all the back to the camera on the tail gate. Any help would be greatly appreciated!!
  2. Jun 1, 2020 at 2:19 PM
    Professional Hand Model
    Hand Protectors
    OMG!!!
    Maybe follow some of the other wires under the truck like your tow or brake looms?
    BestGen likes this.
  3. Jun 1, 2020 at 2:43 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Lilsuge40[OP] likes this.
  4. Jun 1, 2020 at 4:14 PM
    I used the reverse trigger for the backup lights for the backup camera. There are several places at the back of the truck to tap into this. The video signal wire I ran through an existing wire loom (as PHM has suggested) under the bed all the way back to the cab. Then ran it up under the dash to the radio. Best of luck. If you have a handy friend, bribe them with beers for help.
  5. Jun 1, 2020 at 4:24 PM
    Mnorris1206
    08 tundra
    If its a keenwood like mine where you can press a button to see it whole driving as well. Then hook the wire up to you running light wire at the back tail light.
  6. Jun 1, 2020 at 5:55 PM
    speedtre
    speedtre New Member
    Inland Northwest
  7. May 22, 2023 at 7:27 AM
