How to run 285 75 r17 tires or bigger
Discussion in '1st Gen Tundras (2000-2006)' started by Gibson24, Jun 6, 2018.
  1. Jun 6, 2018 at 11:10 AM
    Gibson24
    Gibson24 [OP] New Member
    06 double cab 4.7 tundra
    3200$to front end
    I just want to run a bigger tire like this and a little wider so the tire will stick out some but the 285 75 r 17 doesn't stick out enough and I also have issues with the upper control arms. I put mrt spc adjustable s on it and they didn't work. I've got a leveling kit on it as well. Please help
  2. Jun 6, 2018 at 1:37 PM
    Casper421
    In the woods
    06 DC
    Install wheel spacers or 17’s with a lower offset.
  3. Jun 6, 2018 at 1:38 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Wheels or spacers will determine the “stick out” look
    jewsNbrews likes this.
  4. Jun 9, 2018 at 8:45 PM
    garnaz
    garnaz New Member
    Have this size and 1 1/2 inch back spacer on mine. Make sure if you use spacer that you get extended thread lug nuts for front.
  5. Jun 9, 2018 at 9:12 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Cut, cycle the suspension to see what's still in the way, and then cut until it clears. For the control arm interference you'll need different wheels or spacers.
