HOW TO: Retrofit Install Guide (by EleDobleU)
Discussion in 'Lighting' started by eledobleu, Dec 9, 2016.
  1. Dec 9, 2016 at 8:20 PM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Install guide for people with Retrofits.
    PARTS
    WIRE DIAGRAM (HID KIT)
    WIRE DIAGRAM (PLUG N PLAY HARNESS
    SWITCHBACK AND CONNECTORS
    Orange wire is switchback wire. This wire must be spliced into driver side (red wire) and passenger side (pink wire) turn signal harness. You must also do the "Amber DRL Delete Mod" (Scroll down for instructions) to use your switchbacks. If you don't, when you start your truck your LED's will be Amber.
    If you do not want switchbacks, just don't connect the wire.
    FUSE TAP
    Adjust Vertical Beam
    DRL DELETE MOD
    1. Remove dash panel (since cab). Its the panel where the mirror controls, door light switches and leveler knob is.
    2. Locate Flasher Relay
    3. Locate the SMALL GRAY WIRE (not the big wire). Its two vertical rows, it will be on the first row of wires.
    4. Cut small gray wire.
    Done.
    Tundra_Dawg, =57=, MTwiford and 13 others like this.
  2. Dec 9, 2016 at 8:46 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Thanks Leo! Just as soon as I get my retro's back I'm going to lay out my stuff on the floor and copy your diagrams to help me make sense of everything. Hopefully by doing so I'll have an easier time understanding the installation.
    SouthBoundSteve likes this.
  3. Dec 9, 2016 at 8:54 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Very Nice! Thanks for posting this. It will really come in handy to everyone.
  4. Dec 10, 2016 at 6:30 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    That's great. Maybe @Sean266 or @csuviper can add this thread to the DIY / Mods post
  5. Dec 10, 2016 at 7:30 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    This is a slick write up.
    Thanks Leo!
    bama1302 and SouthBoundSteve like this.
  6. Dec 10, 2016 at 7:47 AM
    :thumbsup:
    SouthBoundSteve and r4z0r51o like this.
  7. Dec 10, 2016 at 7:51 PM
    eledobleu
    Orlando, FL
    Yes just follow the guides to raise the beam higher.
    TRD15559 likes this.
  8. Dec 10, 2016 at 8:40 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    @eledobleu Do you think powering LED strips and halos from the little gray wire work instead of the ign tap option? That idea was in my head for the last days maybe go to try it some day, I mean cut the gray wire and then tap the LEDs harness to that wire and keep the DRL function as is from factory, I'm not sure if this power line shut off of when headlights are on or just dim the ambers this is a raw idea don't have my retros yet to see if this work
  9. Dec 10, 2016 at 8:45 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    I know the ambers still come on when the headlights are on but maybe disconnecting the third wire from ambers and tapping this with the dim function wire in the LED strip to make the LED DRL dim when the side maker lights and headlights are on, I think this is how the OEM drls should work, I don't have a platinum or 1794 to see how they work
  10. Dec 10, 2016 at 8:47 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    By default OEM LED strips DRLs stay at full intensity as DRLs and when side makers and headlights are on the DRL strip Dim to 30-50% intensity, I'm going to try with a multimeter when I have my retros.... some day
  11. Dec 13, 2016 at 7:23 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Does anyone know of another fuse to tap into besides the "ING" (Ignition) fuse? The reason I ask is because I already have little LEDs (Raptor) tapped on that fuse. I can move them, but still need another fuse to tap into. Thanks..!
  12. Dec 13, 2016 at 8:01 AM
    eledobleu
    Orlando, FL
    You can tap into the cig lighter. Its only 12v when the ignition is on.
    letterman52 and SouthBoundSteve like this.
  13. Dec 15, 2016 at 9:18 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Is the passenger side ground bolt already there or need to drill a hole with a new bolt? I haven't looked under the hood yet.
  14. Dec 15, 2016 at 10:29 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I installed my buddy's retrofit by @eledobleu while he was deployed. Both grounds were there; no need to drill new holes or get new bolts
    iHacker and TTU19[QUOTED] like this.
  15. Dec 15, 2016 at 10:37 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Awesome, Thank You! I dont think there is anything else I'd need to pick up prior. Everything is there and straight forward.
  16. Dec 15, 2016 at 11:05 AM
    r4z0r51o
    Dave
    @eledobleu, So to make sure I'm on the right path. If I want to retain my Amber DRL function so that I can use my VLed switchbacks as such, I would not do the DRL delete mod you mention. Also, if I don't connect the orange switchback wire, my LED strip and shroud will remain white. Lastly, by following your guide, when will my LED strip and shrouds light up ... As soon as I turn on my parking lights or as soon as I start up my truck?
  17. Dec 15, 2016 at 11:07 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    yeah, I had to call Leo when I first saw all of the wiring, but after just a short overview, the install was very straight forward. At the time, I wasn't even researching retrofits, so I had no idea about anything. Of course, now I'm interested in getting it done, so I've researched it to death.
  18. Dec 15, 2016 at 11:10 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I have a set of retros from eledobleu. I did not activate my switchbacks or delete the amber. The LED strip and shroud lights up as soon as you start the car and stays lit until you shut it down. It is not dependent on any light positions or switches.
    Cat3ILS and iHacker like this.
  19. Dec 15, 2016 at 11:11 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Using the wire tap to the IGN fuse, they will come on when you start the truck and stay on until you turn it off, regardless of your headlights.
    r4z0r51o[QUOTED] and iHacker like this.
  20. Dec 15, 2016 at 11:17 AM
    r4z0r51o
    Dave
    Yeah, that's what I'm seeing ... I was hoping to figure out how to wire the strips and shrouds to come on only after turning on our parking lights. I wonder if I tap into the parking light if that would supply enough power to run the strip/shrouds.
  21. Dec 15, 2016 at 11:18 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    Following his directions with the IGN fuse tap your LED DRLs will light up just after your key is in the ON position
    r4z0r51o[QUOTED] likes this.
  22. Dec 15, 2016 at 11:23 AM
    r4z0r51o
    Dave
    Yep ... I was hoping to only have my Amber DRL's on during day time usage (with my VLeds as switchbacks) and then only having the strip/shroud on when I turned on my parking lamps.
  23. Dec 15, 2016 at 11:36 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    That look easy just tap your harness to the parking lamps to power on your shroud and strip only when you turn on your lights, this is how the LED Strip in spyders work
    Ground your black wire and red wire taped to the parking lamps that simple
  24. Dec 15, 2016 at 11:54 AM
    r4z0r51o
    Dave
    Exactly what I was thinking ...and exactly how I want my lamps to work, just like our Spyder headlamps. Just trying to confirm with @eledobleu if that would work.
    Not sure about the black and red wire though? Would that be necessary, and if so ... How would one go about doing that? I'm trying to remember how the Spyders are wired.
  25. Dec 15, 2016 at 11:56 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I'd just plug and play with the different fuses there and see which works for how you want. "Head L*" something fuses all correlate with your headlights. They are right next to the IGN fuse.
    iHacker likes this.
  26. Dec 15, 2016 at 12:05 PM
    r4z0r51o
    Dave
    I think I'll just have to wait until my lamps arrive and layout everything and compare Leo's guide with how the Spyders are wired and go from there. In the meantime, hopefully Leo will have something to say to help enlighten me.
  27. Dec 15, 2016 at 12:08 PM
    letterman52
    letterman52 New Member
    So what exactly is a switchback?
  28. Dec 15, 2016 at 12:08 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I'm sure he will. The nice thing is that the projector lamps are completely separate from the LEDs. So you can hook all that up and then mess with the LEDs.
    When I did my Raptor lights, I wired everything and then tried the fuse tap in different places. Doesn't hurt anything.
    BTW, what projectors did you get, the 4.0s?
    r4z0r51o likes this.
  29. Dec 15, 2016 at 12:09 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    They are white until you turn on your blinker, then they turn amber/orange and blink. When blinker goes off, they "switch back" to white.
    Fishing Tundra and Cat3ILS like this.
  30. Dec 15, 2016 at 12:22 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    That would be a clean way to go no taping wires :thumbsup:
