How to remove upper control arm from spindle?
Discussion in '1st Gen Tundras (2000-2006)' started by potoghi, May 27, 2021.
  1. May 27, 2021 at 7:40 AM
    potoghi
    potoghi [OP] Tundra4Life
    Hawaii
    United States
    A2459827-6952-4211-B61E-809B4211CA52.jpg What would be the best way to remove the spindle from the upper control arm? I’ve given a few wacks with a hammer and digging bar but it just won’t budge.
  2. May 27, 2021 at 7:49 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I've used a floor jack and a nice 2x4 wedged underneath the UCA to pop it up. YMMV but that's before I bought proper tools.
    des2mtn and potoghi[OP] like this.
  3. May 27, 2021 at 7:55 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    A pickle fork will pop it right off. Good luck.
  4. May 27, 2021 at 7:58 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Go rent a ball joint remover from autozone it’s free just leave a deposit
    Voss, Cg13055 and potoghi[OP] like this.
  5. May 27, 2021 at 7:59 AM
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    Rubber mallet. Wack it from underneath.
  6. May 27, 2021 at 8:15 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    $20 at autozone balljoint seperator takes 1 minute to remove. I love mine for the rare occasion
    potoghi[QUOTED][OP] likes this.
  7. May 27, 2021 at 8:20 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I tried all of the above suggestions with no luck. This is what I used
  8. May 27, 2021 at 8:26 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you don't care about that ball joint then use a pickle fork and a small sledge. Whack that thing hard, it has to go all the way in and it will separate. It will destroy the ball joint.
    15whtrd likes this.
  9. May 27, 2021 at 8:28 AM
    you need a bigger hammer
  10. May 27, 2021 at 8:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  11. May 27, 2021 at 9:32 AM
    potoghi
    Hawaii
    United States
    51CBF38F-6559-42E3-AFF5-EC406093BCA8.jpg 3D566527-4033-4F4B-82BA-7AAED72C574B.jpg The darn thing just refuses to budge
  12. May 27, 2021 at 9:37 AM
    Geo4x4
    Geo4x4 New Member
    2010 Rock warrior
    I can see your hammer marks. You’re hitting the actual ball joint. You need to hit the uca where the bolt is. That’ll bust up the corrosion in there and shake it loose. Good luck don’t bend your control arm lol
  13. May 27, 2021 at 9:47 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Flip the fork, you want flat side down and keep at it. It will come free. You have to drive that thing all the way in (thats what she said).
    bmf4069, The Dude, tvpierce and 3 others like this.
  14. May 27, 2021 at 10:02 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I was in a similar situation last year. I ended up using my Sawzall and cutting through the BJ bolt. Then punching the remaining piece back out of the Control Arm went fairly quickly. It just wouldn't come out of the UCA
  15. May 27, 2021 at 10:06 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    A 3lbs sledge helps a lot here. Also it might help to smear a bit of grease on the contacting surface of the pickle fork. It will work though, guaranteed.
    potoghi[OP] likes this.
  16. May 27, 2021 at 10:21 AM
    TILLY
    Massachusetts
    I would try going back and forth. Use a large deep socket that will fit over the stud on the UCA, and with the fork out and some penetrating oil, give it a few good whacks. Then use the fork and repeat the process. Good luck.
  17. May 27, 2021 at 11:10 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The part that really sucks is getting the c clip out once the arm is off.
  18. May 27, 2021 at 11:13 AM
    potoghi
    Hawaii
    United States
    I hope the
    theres a worse part then this part?! I think my truck wants to stay original at this point lmao
  19. May 27, 2021 at 11:19 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Pressing the joint out can be tough by yourself too but stay at it. You can do it.
  20. May 27, 2021 at 1:05 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Pry with the pickle fork and smack the control arm near the ball joint with a heavy hammer/mini sledge; at the same time. This shocks the tapered sleeve loose and is the 'proper' way to use the pickle fork.
    tvpierce likes this.
  21. May 27, 2021 at 1:14 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I remember when attempting this job I bought a cheap pickle fork and pried so hard it bent. The upper ball joints are a bitch on this truck, especially with the tool from Advance that doesn't really fit the wheel well. I'm confident you'll get this eventually. Just take a break when you get frustrated.
  22. May 27, 2021 at 1:23 PM
    potoghi
    Hawaii
    United States
    I have given up for the day and will try again tomorrow with a bigger hammer. I also have to get another mallet now too lol.
  23. May 27, 2021 at 1:26 PM
    potoghi
    Hawaii
    United States
    EE4471C7-7088-4DEB-B28A-8A3A552C83AF.jpg I actually might get a shop to do it for me at this point though. I don’t wanna cause more damage than I already have.
    does it look okay to drive with still :oops:
  24. May 27, 2021 at 1:26 PM
    Torch time
  25. May 27, 2021 at 1:52 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Send me a plane ticket and I'll knock that thing out.
    bmf4069, N84434, FirstGenVol and 3 others like this.
  26. May 27, 2021 at 3:19 PM
    You need the small ball joint press to push that thing out at this point. You can get a no cost loaner from most parts stores.
  27. May 27, 2021 at 3:28 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    I'm sure there is a perfect meme to place here.
    All I can say is....:eek2: stop.. save your time and money take it to a qualified shop.
    Don't want to have to replace anything else that you don't have to.
  28. May 27, 2021 at 3:49 PM
    Are you using a ball peen hammer? Mighty small dings in that ball joint bucket. Need a 3-5# sledge
  29. May 27, 2021 at 3:52 PM
    Dr Doobie
    Talkeetna,Alaska
    It's time for a torch, a press and a pro
  30. May 27, 2021 at 3:59 PM
    potoghi
    Hawaii
    United States
    I’m gonna give it one more wack tomorrow if it doesn’t say uncle I’ll take it to a shop next lol
    D4x4TRD and Dr Doobie[QUOTED] like this.
