How to remove Leveling Kit? Bought this truck and want it to go back to stock.
Discussion in '2.5 Gen Tundras (2014-2021)' started by JKTrevecca, Jul 31, 2020.
  1. Jul 31, 2020 at 6:35 PM
    JKTrevecca
    JKTrevecca [OP] New Member
    2014 1794 4x4
    Hello! First time on this forum. My name is Jason. I live in the Nashville, TN area and purchased a 14 Tundra on Monday. I love the way it looks but I don't think I'm a lift/mud tire guy which leads me to my questions. If I want to remove the leveling kit 2.5 / 1.5, and go to stock sized tires, do I need to do anything other than remove the spacers under the leaf springs, remove the spacers above the front shock/struts, and get the truck aligned?
    Anybody want to trade some like new TOYO Open Country M/T's 35x12.5x20 and my leveling kit for a set of new OE take-offs?
    Cheers and thanks in advance! Here are pix of what I've got. Are there modifications I need to un-do other than removing these spacers?
    Blueknights75 and Sunnier like this.
  2. Jul 31, 2020 at 6:56 PM
    Sunnier
    Sunny
    San Diego, CA
    I can only see what you’ve posted, but yes, it looks like you just need to remove those spacers, front and back. And replace the shackles in back.
    Someone gave away brand new OEM shocks on here a couple of weeks ago, and others sell ‘em for very low prices, because most people swap em out— I feel certain you’ll find a taker to swap soon.
    FWIW my 3rd gen has stock TRD suspension and OEM tires and I’m very happy with it. That said, your “stance” will be a bit different, and the look you love may be altered. But it will ride a lot better without those spacers.
    EDIT: I wrote shackles but I was thinking U-bolts and, since OP didn’t mention U-bolts while asking about going back to stock, I wanted to give a heads up not to reuse any.
    (Thank you @1lowlife for inviting this correction. Three times.)
    Black Wolf likes this.
  3. Jul 31, 2020 at 7:22 PM
    Me personally I would leave it the way it is.
    Blueknights75 likes this.
  4. Jul 31, 2020 at 7:25 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Welcome from Oregon!
  5. Jul 31, 2020 at 7:26 PM
    Sunnier
    Sunny
    San Diego, CA
    Depends on how he wants to use it. If he wants to do off-road driving, it’s always a good idea not to have spacers.
  6. Jul 31, 2020 at 7:29 PM
    I took my spacers out too....for these.
    SMK Shoe and Sunnier[QUOTED] like this.
  7. Jul 31, 2020 at 8:08 PM
    Sunnier
    Sunny
    San Diego, CA
    Good decision! Keep that truck awhile. :boink: (That’d be another good decision.) :p
  8. Jul 31, 2020 at 8:33 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Just remove the blocks and spacers.
    You probably have OEM black shocks and struts already, no need to replace them.
    But you will need to replace the tires, probably have some rubbing when you remove the spacer and blocks.
    YardBird likes this.
  9. Jul 31, 2020 at 8:34 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Why would he do that, he already probably has stock shackles?
    Someone just added the cheap block.
    He might need stock U-bolts to ditch those blocks.
    Boerseun likes this.
  10. Jul 31, 2020 at 8:56 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Not sure why you would want to go through the trouble. Your '14 looks damned nice with the leveling kit and tires! But hey, different strokes, right?
  11. Jul 31, 2020 at 9:20 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes, stock U bolts would be good. My understanding is, this is something that needs to be replaced though, not reused.
  12. Jul 31, 2020 at 9:22 PM
    Sunnier
    Sunny
    San Diego, CA
    Maybe I’m mis-remembering. I think I learned this from something @831Tun shared. Warren, can you please correct my error, if I’ve made one.
    joonbug and 831Tun like this.
  13. Jul 31, 2020 at 9:39 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You got it right Sunny, U-bolts should not be reused.
    OP, the shocks look like stock shocks in the photos so you probably don't have to replace 'em. Spacers and stock shocks is not ideal. Can't see the shackles but they're probably stock too. So, just remove the spacers, throw 'em in the trash, I mean recycling, replace the U-bolts and get an alignment.
  14. Jul 31, 2020 at 11:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Find some TRD OR take offs and replace with those while you’re at it. Can probably find some for $100.
  15. Aug 1, 2020 at 6:53 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    The blocks use the stock shackles, why would he replace them?
  16. Aug 1, 2020 at 7:35 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Haven't seen mentioned but the front end will need an alignment as well if the front spacers are removed.
    I think it looks great. If not off-roading much I would leave as is.
  17. Aug 1, 2020 at 7:46 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Also need to check and see if it has front diff spacer installed and remove that too. Definitely and alignment after like Trooper2 stated
  18. Aug 1, 2020 at 7:54 AM
    Sunnier
    Sunny
    San Diego, CA
    I wish I better understood why, but I’ve made a mental note never to reuse U-bolts. My understanding (a guess based on examination + forum reading) is that the nuts/bolts, once backed off for removal, won’t be as secure after subsequent installations. Since it’s obviously a critical attachment, and fairly inexpensive, seems like a no-brainer to replace them rather than re-install.
  19. Aug 1, 2020 at 7:58 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's 'cause the U-bolts stretch when installed and tightened. After install and torquing to spec they need to be re-torqued after a few hundred miles. When removing I've found galling often occurs and that compromises the integrity of the threads.
    Sunnier[QUOTED] and gosolo like this.
  20. Aug 1, 2020 at 8:00 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The threads are actually stretched during torque of the nuts.
    Warren, you responded seconds ahead of me, lol
    Sunnier[QUOTED] and 831Tun like this.
  21. Aug 1, 2020 at 8:05 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    What size tires are you running? It would suck if you had some rubbing after you took off the leveling kit
  22. Aug 1, 2020 at 8:06 AM
    Sunnier
    Sunny
    San Diego, CA
    He’s planning to trade tires too!
    831Tun likes this.
  23. Aug 1, 2020 at 8:07 AM
    Danimal86
    Daniel
    Sacramento, CA
    Shit my bad....I stopped reading at the leveling kit and started looking at pictures
    Sunnier[QUOTED] likes this.
  24. Aug 1, 2020 at 8:10 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Are those really 35x12.5x20 tires?
    How did they fit those on stock platinum wheels?
    That would be a bad fit, would be unsafe, and illegal, the wheel is way to narrow for that tire, and would rub for sure. Bmc probably had to be done and Fender issues most likely.
    Got pic of the tire size?
    If that's really the size on the tires, you need to either get those off asap or make the place that sold you the truck replace them with proper size tires.
    I have stock 275x55x20 AT tires on my 1794 with 3in front and 1.75in rear lift. They look smallish, but not God awful imo. I will be getting bigger ones eventually, your size with proper new wheels that are wider with different offset.
    You can also easily fit 275x60x20 tires on stock lift.
    You may also have wheels spacers behind those wheels as the stock offset with that tire size would rub alot.
  25. Aug 1, 2020 at 8:11 AM
    Sunnier
    Sunny
    San Diego, CA
    Thank you! Next time I may remember the “why”. Baby steps.
    gosolo and 831Tun[QUOTED] like this.
  26. Aug 1, 2020 at 8:21 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    It's a sharp looking truck. It would be tough to go back unless I was upgrading...
    Seafury likes this.
  27. Aug 1, 2020 at 8:49 AM
    Seafury
    Agent K
    SC Low Country
    BTW, those tires are super sweet and like $450+ each new.....
    If I was closer, I'd trade you faster than a new York minute lol.
    Sunnier and HulkSmurf14 like this.
  28. Aug 1, 2020 at 8:58 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I'm not asking you about the u-bolts, that's a no brainer.
    He has to take them off and they would be too long without the blocks anyway.
    You stated to replace the shackles, I'm still waiting for a response as to WHY?
    Third time to ask..:confused:
    Seafury likes this.
  29. Aug 1, 2020 at 9:23 AM
    Sunnier
    Sunny
    San Diego, CA
    Because I wrote it wrong. By the time I noticed what I did, Warren had answered up, and also quoted my post, plus I noted your tag line— I just decided to leave it alone.
    Good of you to have the patience to point out my error. Three times. :)
  30. Aug 1, 2020 at 12:46 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    If you would of addressed and answered it the first time I wouldn't have asked you again.
    You're welcome..
