How to remove a dealership badge
Discussion in '2.5 Gen Tundras (2014-2021)' started by zoomLENS, Mar 15, 2019.
  1. Mar 15, 2019 at 12:56 PM
    zoomLENS
    zoomLENS [OP] New Member
    2015 Tundra TSS SR5 2wd
    So my 2015 has a small dealership badge on the tailgate that has always bothered me and I want it off. Its either cheap metal or plastic(most likely)and has very little tolerance between the paint and the badge itself. Im afraid that if I use a prying instrument that will damage the paint etc. Has anyone had experience with this? It's paid off and I hate advertising for them. Always have. Thanks!
  2. Mar 15, 2019 at 12:58 PM
    15whtrd
    15whtrd Mr. Blonde
    Get it nice and warm and use fishing line. Then your choice of goof off, WD-40 etc. to get the glue off. Then give it a little polish and wax.
  3. Mar 15, 2019 at 1:00 PM
    Jeff_1974
    Jeff_1974 Cookeville, TN
    Jeff
    Tennessee
    2010 supercharged rock warrior dc
    Supercharger Bama Exhaust Bully dog tune Bed extender Roll up Bed cover Bed carpet 18” Method wheels Falken wildpeak 285 75 18 P & P rock sliders Weather tech floor mats Sdhq pre runner bumper Warn 9.5 xp synthetic winch Icon 2.5” lift Iron cross rear bumper RCI al skids Trd brake pads Trd front sway bar Deaver u748 leaf springs Marathon seat covers
    Use a hair dryer or glue gun to heat the badge. At the same time run fishing line behind the badge.
    May take a few minutes.
    Goo gone should remove any residue from the badge’s glue.
  4. Mar 15, 2019 at 1:05 PM
    15whtrd
    15whtrd Mr. Blonde
    Glue gun??
    Black Wolf likes this.
  5. Mar 15, 2019 at 1:07 PM
    Jeff_1974
    Jeff
    Tennessee
    Anything that will heat the badge and loosen the glue. If you heat it hot enough, badge will just about slide off. Gloves may be needed though.
    15whtrd[QUOTED] likes this.
  6. Mar 15, 2019 at 1:13 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Exactly. Most of the time just a length of fishing line used in a sawing motion will do it. The residue came right off mine with a little bit of wd40 on a rag
  7. Mar 15, 2019 at 1:41 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    I had one on an 95. I just pulled it off. It was double sided tape, the thicker foam style, that just split in the middle and then used a goo gone. Sounds like this is thinner? Adhesives probably way better now.
  8. Mar 15, 2019 at 1:42 PM
    zoomLENS
    Thanks all for the insight and tips. Ill have that damn thing off in no time. Very excited.
  9. Mar 15, 2019 at 1:43 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    I use a heat gun and dental floss or fishing line. Just take your time heating it up. go slow on a low heat. I use a 3m eraser wheel when I am done, sometimes I use rapid remover if needed (Amazon). Then i buff or correct any ghosting or marks left.
  10. Mar 15, 2019 at 1:48 PM
    Ronin
    Ronin Hoof Hearted
    Bill
    2019 CrewMax 5.7 Tanker
    Goo Gone, a stiff fart & WD40 will also remove the thin water based clearcoat IMO. I just used several waxing's of the area. Safest IMO.
