How to put truck in neutral with ignition off
Discussion in '3rd Gen Tundras (2022+)' started by Hopsdevil, Sep 16, 2024.
  1. Sep 16, 2024 at 3:01 PM
    Hopsdevil
    Hopsdevil [OP] New Member
    Dave
    Kennett Square, PA
    2023 Dbl Cab Lunar Rock
    Does anybody know how to put the truck in neutral with the ignition off so it can be pushed? I need to push it to get it onto a lift. I can’t drive it in because the doors are too close to the lift’s uprights making getting out of the truck impossible. When it’s in neutral the ignition won’t turn off and when I get out to push it, it starts buzzing loudly.
  2. Sep 16, 2024 at 3:09 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Turn the ignition to on without pressing the brake?
    turn it off in neutral?
  3. Sep 16, 2024 at 4:52 PM
    Hopsdevil
    Dave
    Kennett Square, PA
    That didn’t work. Still get message to put it in park before exiting. And still screams at me.
  4. Sep 16, 2024 at 4:53 PM
    Fxclm5
    Fxclm5 New Member
    Check the manual, I recall some procedure and pulling on something?? That was my old ram
    Nvm, it's the old school mode, look to right of shifter lift up the plastic tab,shove a flathead to activate the switch to move the shifter into N
  5. Sep 17, 2024 at 4:07 AM
    Observer
    Observer New Member
    Tundrastruck91 likes this.
  6. Sep 17, 2024 at 4:32 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    Put it on the lift and crawl out the back window into the bed.
  7. Oct 26, 2024 at 9:10 AM
    Zadams333
    Zadams333 New Member
    Zach
    So you can put it in neutral if the battery is dead but how do you disengage the electric parking brake
  8. Oct 26, 2024 at 9:31 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Jumper cables or battery pack
