How to mount recovery boards on a budget?
Discussion in 'General Tundra Discussion' started by Rica25, Aug 25, 2021.
  1. Aug 25, 2021 at 8:51 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Bought some recover boards for the FJ Whats the easiest way to mount with out spending to much money?
  2. Aug 25, 2021 at 8:52 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    HF ratchet straps or bungees :D
    Kgfit85, Rica25[OP] and Gravy like this.
  3. Aug 25, 2021 at 9:05 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I actually laughed, thanks Snivilous! Post a pic of your FJ so we can see what your working with.
    snivilous[QUOTED] and Rica25[OP] like this.
  4. Aug 25, 2021 at 9:09 PM
    Rica25
    Ricardo
    Tulare
    GODZILLA likes this.
  5. Aug 25, 2021 at 9:12 PM
    Rica25
    Ricardo
    Tulare
  6. Aug 25, 2021 at 9:16 PM
    Gravy
    Yucaipa, California
    Snivs answer is the easiest, but if you want a more permanent solution thats cheap you could drill some holes in the cross members on your roofrack (match the mounting points on your boards hopefully) and use some stainless bolts, washers, locknuts to make mounting points on the crossmembers. Then use some rubber washers, stainless fender washers, lockwashers and wingnuts to mount the boards to the bolts. If you can toss up a pic of your rear end, theres probably a solution for mounting them to that spare tire/rack.
    P.s. stainless hardware isn't cheap, galvanized works, but you will get some rust.
    Rica25[OP] likes this.
  7. Aug 25, 2021 at 9:31 PM
    Gravy
    Yucaipa, California
